Author Topic: Test Jig to Test Relay D1D40  (Read 663 times)
Offline dareswitchTopic starter
« on: May 28, 2019, 05:18:16 am »
Hello All,
I'm very new to this forum and still working out my electronics skills in  designing.
Can some one please help me to build a circuit to test a Solid State Relay unit D1D40.
Have a circuit with  - SPDT switch and 4 LED (companied with ressitors)and then used 8 x 180Ohm Resistors at the load end of D1D40 relay which get very hot upon operation and i want to come up with a solution for this problem .
Please see  4 LED are used  for below purposes in my circuit-
 1st LED - Power ON indication
 2nd LED - to indicate whether the Relay is Active
 3rd LED - to indicate Fail open
 4th LED - to indicate FAIl Closed
BUt i need something simple but everything covered.
Kindly suggest
Thanks
« Last Edit: May 28, 2019, 05:26:33 am by dareswitch »
Offline Simon
  • Global Moderator
    • Simon's Electronics
Re: Test Jig to Test Relay D1D40
« Reply #1 on: May 28, 2019, 05:22:12 pm »
Please don't post the same text twice, it really annoys people.
