We have just bought a new TTI CPX200D power supply for our lab, and it arrived today. We needed a power supply with remote sense capability to better power an RF board. The supply arrived this morning and we tested it for voltage and current and with some loads and everything looked OK, so this afternoon we proceeded to test the RF board. We had powered up the RF board previously with another supply without problems, but there were issues with voltage drop in the wiring.
We setup everything following both the supply manual and the RF board manual. The RF board gets its power from a connector, and outputs the two power sense lines, connected directly to the supply voltage and ground at the power connector. We twisted the sense wires together and connected them to the SENSE inputs of the supply, and connected the power wires to the output terminals. We switched the supply to remote sense, triple checked the connections polarity, adjusted voltage and current limit (the RF board is powered at 1.8V 1A, but the manufacturer recommends starting it with a 50mA current limit just in case and then raising it, so we set the current limit to 50mA) and proceeded to connect the power connector to the RF board, all of this with the supply output DISABLED.
Just when the power connector was starting to mate with its socket in the RF board, a tantalium capacitor connected across the power rail just at the RF board power connector blew up and started burning, and the board is now ruined. The RF board was worth 10000€. There was no other energy source for the RF board, no other active thing was connected to it. No instrument was connected either. Nothing. It has a single supply rail at 1.8V, we had succesfully powered it up before several times and, again, the output was DISABLED. With no other energy source available for the RF board, the energy responsible for blowing the capacitor (220 uF 16V tantalium cap) had to come from the power supply somehow. The thing is, we also had a multimeter connected accross the power lines monitoring the output voltage and it said 0V. Sense and power rails get tied together when the power connector is mated with the RF board, and these sense lines were the only non-monitored part we had. We checked afterwards that with the output DISABLED the sense lines remain at 0V and that there is no transient nor anything when power and sense lines get tied together.
Do you have any theory about how this happened?
EDIT:
Here's an update. During this time we tried simulating the board with a dummy load, consisting of an electrolytic capacitor with similar specs to those of the tantalum that blew up (electrolytics can tolerate much more without blowing up with toxic smoke) and found some interesting things.
If you proceed exactly as we proceeded when the incident happened (power supply channel turned off), nothing happens. The output stays at 0V, no transient, no nothing. No matter how you connect the supply to the dummy load, nothing happens. If the capacitor is pre-charged it just discharges with a nice exponential curve (so the output has confirmed bleeding resistors)
If you then turn on the supply with the dummy load already connected, the output just rises nicely to 1.8V, no overshoots or weird stuff.
BUT, if you turn on the power supply channel with the dummy load disconnected and you then hot-plug the dummy load, in some cases there's a several 10's of volts transient (>40V), almost 3 seconds long, and then the output stays at 1.8V. That scenario would have explained our issue... if it wasn't for the fact that the PSU supply channel was disabled. We triple-checked that it was indeed disabled before plugging anything. Both my colleague and I are 100% sure that it was off.
We'll keep investigating... (the manufacturer hasn't answered yet, we'll try new communication channels).
