Hi all! Some of you might possibly remember one of my million billion threads on my DIY gas chromatograph.
I'm currently designing the next detector, which is a 4-element wheatstone bridge of tungsten filaments (3mm ground-open light bulbs).
I've never done much design work with instrumentation amplifiers, or wheatstone bridges for that matter, but i've settled on the AD8226 ins. amp.
I'd be thrilled if you'd look at my design so far and see if it's reasonable. See attached schematic.
I have a current source, a small potentiometer in the bridge to balance it out for a zero reading, an attenuator, and then the amp with variable gain. I'm leaving gain as a potentiometer for now as well, as I don't know the sensitivity of my sensor filaments yet, in the future that might be fixed, and the (stepped) attenuator used to reduce the signal if very concentrated samples are analyzed.
Is there any reason not to go single-rail on the bridge and amp? I want to input the amp output into a 5V analog atmega pin, is it better to have my amplifier at 5V supply or the full 24V and then put a diode clamp on the output?
Thanks for your interest!
--Chris
