Author Topic: PCB trace impedances of integrated circuits with high input impedance  (Read 317 times)
Offline electronxTopic starter
There is an ADC front end IC (opamp) at the input of my ADC card and it has high input impedance, What should I set the differential trace impedance to when drawing the PCB? Does this matter much?
« Last Edit: May 13, 2024, 12:20:42 pm by electronx »
in god we trust
Online moffy
For a 0-20kHz frequency range the trace impedance is not an issue, but if you have to run them any length keep them close to one another to reduce differential pickup.
Offline shapirus
  • Country: ua
It depends on the speed of the signal (edge rise/fall times), source impedance, and the length of the traces between the source of the signal and the ADC.
What numbers are you dealing with in terms of the above?
« Last Edit: May 13, 2024, 04:12:19 pm by shapirus »
