Author Topic: Best way to cheaply measure AC current  (Read 433 times)
Offline Dejan567Topic starter
« on: May 14, 2024, 12:53:41 am »
This is reference to my earlier post: https://www.eevblog.com/forum/projects/weird-coil-configuration-does-it-classify-as-parallel-lc-circuit/
Please refer to this post and specifically Reply #24 for more information about the exact set up. I am looking to measure the current on either the input or output as accurately as possible without buying a super expensive current probe or wasting a lot of power. If having to choose, I would rather do the latter.
The current probe I currently have is MicSig CP503B, which to my understanding can measure only 20 mA reliably. Again, I am working in kHz to low MHz range. Budget is, of course, limited.
I am using a signal generator to drive my circuit. Now I know impedance matching is a significant issue here as well so looking for suggestions or to know if it's even possible  (and how to do it, precisely). I was thinking of using a precise resistor in series and measure the voltage drop across it but again there is the impedance matching issue.
Any suggestions? Please give as much detail as is possible.
Online moffy
Re: Best way to cheaply measure AC current
« Reply #1 on: May 14, 2024, 01:41:01 am »
This is a reference to an open source wideband current sensor, you probably just need the current transformer and amplifier not the Hall effect part: https://www.sciencedirect.com/science/article/pii/S2468067218300592
Offline aliarifat794
  • Country: bd
« Reply #2 on: May 14, 2024, 06:45:12 am »
The cheapest that I can think of is ACS712. ACS712 is an AC or DC current sensor, which is used to measure AC or DC current. You should also have a look at Difference between AC & DC Power, that will help. The maximum value of AC and DC which can be measured is 30A, its output current signal can be read via analog I/O port of Arduino.
https://www.theengineeringprojects.com/2019/03/introduction-to-acs712.html
Here is how you can measure AC current with ACS712 and Arduino.
https://microcontrollerslab.com/ac-current-measurement-acs712-arduino/
