An LED driver, ZXLD1360, have a dim pin, to be driven by PWM.
To get full 1:100 dimming range, it should be driven at under 500Hz.
As a result, the LED is essentially driven with a PWM waveform, with peak at it's full current's voltage, and zero in-between.
Question is - how does that affect the power dissipation?
Obvious part is that the heat dissipation will be based on LED's full power efficacy point, which is less than what it would be at the lower one.
Less obvious is - how does the fact of PWM affect it?
Let's say the LED have Vf of 15V at 1A current. Normally, it would dissipate 15W (ignoring the *0.75 factor for light output).
If it was to be driven at 0.25A, it would have Vf of about 13V, and power dissipation of 3.25W.
However, what values to use for driving it with a 0.25 duty cycle PWM?
Is it RMS current, I=Ip*sqrt(D) = 0.5A?
What about Vf?
Assuming Vf of 1A, it would be 7.5W.
Assuming Vf of 0.5A, it would be 6.75W
Assuming RMS Vf, it would be 3.75W
Which one is it?
Basically, how to estimate the power dissipation of an LED driven by PWM?
