I'm working on a project that uses an inductive sensor and it's quite temperature sensitive so i'm getting a fair bit of drift as the ambient temperature changes.
The sensitivity is greater than I can measure and mathematically compensate for with a regular linear temperature sensor (MCP9701A) or even with a thermistor despite the thermistor being 3 times better I still need greater resolution. Part of the limitation is the 10bit ADC I'm using to measure it and I'm not really in a position to change that because it's sitting just above the noise floor.
I'm thinking that what I need is a way to warm the enclosure 110x190x70 to a configurable temperature and hold it there.
With that in mind I thought I'd try 150mA through a power resistor with it heating up together with the heating of the LM7805CD2T having to drop down from the 12v input. Obviously I didn't try and calculate what would be suitable because this wasn't. It warmed the enclosure faster but couldn't hold the temperature when the ambient started to drop.
I know that I can change the components to get more heat generated using more current but I'm really wondering if I'm approaching it wrong so I want to get some ideas about what methods there are to manage temperature sensitive devices without controlling room temperature.
Searching for oven circuits tends to return results on kitchen appliances
