Front end PFC solves a lot of issues, and is often compulsory (i.e. to meet CE). Maybe with a SEPIC topology, if you don't mind the somewhat higher losses -- this avoids the high DC bus of a boost PFC. (Which still isn't a problem with respect to 900V+ transistors being readily available, but gate drivers not so much. There are a few bootstrap drivers that can do that, but most likely you'll need a transformer or fully isolated solution.) With PFC, LLC is reasonable for the iso stage, and probably not a bad idea for the power level and if it needs to be compact. Otherwise, sure a quasi resonant flyback isn't bad, or 2-switch forward/flyback.
Have seen industrial Meanwell and other supplies with 240-480VAC input (or even lower, I forget?), and I think either plain flyback, or 2-switch forward (no PFC). Your power level isn't crazy, a little high for flyback but understandable given the range.
