Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
DisplayPort to DVI
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: DisplayPort to DVI (Read 610 times)
Pack34
Frequent Contributor
DisplayPort to DVI
on:
May 28, 2019, 03:09:30 pm »
I'm looking for the cheapest way to convert a DisplayPort output to a DVI-I (single link) input. Is it really as simple as wiring in a MAX9406 (or similar) chip like the app note below?
https://www.maximintegrated.com/en/app-notes/index.mvp/id/4313
Logged
wraper
Supporter
Country:
Re: DisplayPort to DVI
Reply #1 on:
May 28, 2019, 03:20:20 pm »
Most of displayport outputs are DP++ which means you only need a simple level shifter IC. They already can output DVI signal natively, just with different voltage level.
http://www.ti.com/lit/ds/symlink/sn75dp139.pdf
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
DisplayPort to DVI
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
