Author Topic: DIY 1.8GHz spectrum analyzer  (Read 2956 times)
Offline erikkaTopic starter
« on: June 04, 2019, 01:38:37 pm »
Hi all,
I want to share my latest project, a 1.8GHz spectrum analyzer.
Technology (see first picture):
Double/triple conversion with passive mixer modules from eBay and ADF4351/SI5351 modules from ebay as LO's
Log amp (from AD8307 data sheet) for DIY wide RBW and audio based FFT stitching for small RBW
Arduino zero for embedded control and everything else on PC
SW also DIY based on .net so PC only
Specs:
DC (I tested down to 10 Hz) till 1.8GHz
IIP3 +18dBm (see second picture)
Spur free dynamic range (depending on RBW) at least 70dB
RBW from 300kHz to 1Hz (See third picture) Dynamic range reduced (but still acceptable) at small RBW due to phase noise of ADF4351
Phase noise acceptable (see fourth picture)
And results of an actual measurement of harmonics of a signal generator as fifth picture (ignore the IIP3 text at top of display, forgot to switch of)
All still without shielding so you may notice some spurs
« Last Edit: June 04, 2019, 01:40:25 pm by erikka »
The following users thanked this post: ritesh
Offline Theboel
  • Country: id
Re: DIY 1.8GHz spectrum analyzer
« Reply #1 on: June 04, 2019, 04:39:37 pm »
Very interesting
with max2871 and etc chip get higher is that possible You made this an open project ?
Offline ogden
  • Country: lv
« Reply #2 on: June 04, 2019, 05:43:45 pm »
Wow. Fine job! Could you show some photo of instrument as well? What is RBW and what Resolution? In case RBW is Resolution Bandwidth, in one screen it is 30KHz while span is 20KHz. How's that?
« Reply #3 on: June 04, 2019, 06:01:32 pm »
The RBW is the selected hardware filter bandwidth at 2nd IF.
The actual resolution is displayed at the bottom
It goes from 300kHz an 30kHz for the hardware filters and from 10kHz down to 1Hz in FFT mode
So in FFT mode with 20kHz span and 10k points you get 2Hz bins
« Reply #4 on: June 04, 2019, 06:11:40 pm »
Quote from: Theboel link=topic=191295.msg2462010#msg2462010
I guess yes.
There are no pcb designs or detailed documentation. It is more inspiration . I am still learning
« Last Edit: June 04, 2019, 06:30:13 pm by erikka »
Offline ogden
  • Country: lv
« Reply #5 on: June 04, 2019, 06:25:04 pm »
You can't call it RBW then. Resolution bandwidth most likely is what you call "Resolution". BTW you do not mention detector bandwidth (VBW).
Some "SA fundamentals" books worth to check, maybe answer about common name for FFT "IF filter" width is there:
http://literature.cdn.keysight.com/litweb/pdf/5952-0292.pdf
https://download.tek.com/document/37W_17249_5_HR_Letter.pdf
https://cdn.rohde-schwarz.com/pws/dl_downloads/dl_application/application_notes/1ef77/1EF77_3e_Real-time_Spectrum_Analysis.pdf
« Reply #6 on: June 04, 2019, 06:35:55 pm »
I ment RBW as displayed in the UI
Thanks for the document links.
Offline RoGeorge
« Reply #7 on: June 04, 2019, 06:54:43 pm »
Wow, very impressive!  :-+
Can you put some pics with the hardware, please?
Offline schratterulrich
  • Country: at
    • Elektronik & Layout
« Reply #8 on: June 05, 2019, 06:19:21 am »
Great work and very impressive results.
I have a question:
How do you attenuate the image freqency?
You directly downconvert from 2.6 GHz to 10.7 Mhz. So if you use 2.6107 GHz at the ADE-25MH LO Port how to you attenuate the signal at 2.6214 GHz which will also convert to 10.7 MHz?
« Reply #9 on: June 05, 2019, 07:11:46 am »
Here is a picture, true Arduino prototype style. I annotated the major components
The image surpression works because the cavity filter has very steep edges so I put the first IF at the lower edge of the filter and the second LO below the first IF. Image surpression is not perfect so I added wobbling of the IF frequencies to enable image suppression in SW
I'm still looking for a very narrow cavity filter to improve.
The following users thanked this post: notadave
Offline Theboel
  • Country: id
« Reply #10 on: June 06, 2019, 10:19:37 am »
It's getting better with "eBay ready" parts like that
« Reply #11 on: June 06, 2019, 10:22:05 am »
Nice job! That's seriously impressive work!
« Reply #12 on: June 06, 2019, 03:35:16 pm »
Well... There are some parts you better not order from eBay. I did receive my share of counterfeits and bad parts. Even from known good suppliers
Examples:
ADE-11X being relabeled as ADE-25HM
Mixer module with -27dB conversion loss
ADL5801 module with bad performance
Ultra low noise MICC, 10 pcs, all with twice the normal current so they will self destruct within days
Offline notadave
« Reply #13 on: September 15, 2019, 01:51:36 pm »
How did you know the ADE-11X could output much lower than 5MHz ? Looks like it is meant for IF of 30MHz.
I would not even have had the idea that one could by stuff like that off eBay!
Earlier this year I had the idea to make something similar, but for much lower frequency, with DVB-T ICs or an ADC (I did not have the idea to use a sound card thinking they were 44.1kSps and 16bit.) but a 24bit sound card is a great/better solution.
I concluded that generating the two LO signals in fine steps and without jitter was too hard.
« Reply #14 on: September 15, 2019, 01:59:09 pm »
Many double balanced diode mixer has one port that can go to DC. The port directly connecting to the diodes. Some mixers have a balun between the port and the diodes, those won't work to DC
