Author Topic: Biggest cell capacity for 22 x 22 mm case  (Read 292 times)
Offline Wilson__Topic starter
« on: April 21, 2024, 03:42:18 pm »
Appreciate some advises and insight to find a rechargable cell fitting 22 x 22 mm case.  Would like to find a cell that is higher for bigger capacity, 100 to 300 mAh, with protection chip on cell
Which chemistry is best. Li Ion, Li Polymer or LiFePo4?  TIA
« Last Edit: April 21, 2024, 04:29:09 pm by Wilson__ »
Offline wasedadoc
Re: Biggest battery capacity for 22 x 22 mm case
« Reply #1 on: April 21, 2024, 04:06:25 pm »
Do you live in Flatland?  :)  (https://en.wikipedia.org/wiki/Flatland)
Do you want a cell or a battery?  You have asked about both but they are different things.
Re: Biggest cell capacity for 22 x 22 mm case
« Reply #2 on: April 21, 2024, 04:29:47 pm »
Many thanks.  Edited
