Author Topic: diy breakoutboards  (Read 22104 times)
Offline p.larnerTopic starter
diy breakoutboards
« on: March 11, 2024, 12:23:21 am »
i am looking for pcb artwork for a 14 pin dip breakout board that i can etch,looked on google but no joy,can anyone help?,thanks.
Offline themadhippy
Re: diy breakoutboards
« Reply #1 on: March 11, 2024, 12:30:54 am »
Whats stopping you making yer own with kicad
Offline Kim Christensen
« Reply #2 on: March 11, 2024, 12:33:49 am »
14pin DIP broken out into what? I mean, you can already put a 14pin dip IC into a breadboard, so breaking it out into 0.1" headers seems pointless to me. Unless I'm missing something.
Maybe you meant a DIP proto board?
« Last Edit: March 11, 2024, 12:37:47 am by Kim Christensen »
« Reply #3 on: March 11, 2024, 12:38:43 am »
i want to have the tracks spreading out like flower petals sort of thing to connect things to easyer,i am not good with kikad or would make my own,for some reason sends my pc crazy,the mouse goes nuts!.
« Reply #4 on: March 11, 2024, 12:50:12 am »
You can find them pretty cheap on Amazon, AliExpress, etc. Unless you really want the PCB etching/manufacturing experience, I'd just buy one already made like the ones I linked above.
Offline abeyer
« Reply #5 on: March 11, 2024, 01:04:17 am »
There ya go. That's about as close as you're likely to get unless you actually use some mouth words to precisely define what you want. (or just draw it with a sharpie, which would likely be faster)
« Last Edit: March 11, 2024, 01:06:13 am by abeyer »
The following users thanked this post: TopQuark, factory
« Reply #6 on: March 11, 2024, 03:13:41 am »
i want something where the track from the 14 ic pins allign on one side in a row with big pad to solder too,or 2 rows of 7 pads next to eachother in a line with say a 10mm gab between the 2 rows of paralell pads,its hard to explaine .
Offline Andy Chee
« Reply #7 on: March 11, 2024, 03:50:03 am »
Can you draw it roughly by hand with pencil and paper, take a photo, and post it here?
« Reply #8 on: March 11, 2024, 04:38:58 am »
You mean something like this? Do you really want 10mm between pads? With 4mm pads, that would make the PCB 88mm long.
Offline Nominal Animal
« Reply #9 on: March 11, 2024, 04:48:24 am »
EasyEDA is a good tool for these.  It runs in your browser (and requires an internet connection), but is easy to use, free, and integrates very easily with JLCPCB.
The following users thanked this post: p.larner
Online RoGeorge
« Reply #10 on: March 11, 2024, 07:52:38 am »
Guerilla breakout boards out of single-side veroboard:  8)
The idea is to cut the veroboard pads in half, such that each newly created copper half-pad will match the SOIC footprint.
Pics from https://hackaday.io/project/7574-the-devil-is-in-the-details/log/26074-diy-breadboard-friendly-soic-breakout-boards
Looks easy, but it's way more time consuming than soldering chips on proper breakout boards.  Either way, it is preferably to use round pins if you intend to insert the breakout board in a breadboard.  Square pins are cheaper and easier to source, and they still fit in a breadboard, but they are much too thick for breadboards.
« Last Edit: March 11, 2024, 08:02:04 am by RoGeorge »
Offline tggzzz
« Reply #11 on: March 11, 2024, 09:17:25 am »
Personally I would use an unetched PCB, dremel and a dental bur, ideally spherical. With a small amount of practice, you can get surprisingly good results that way.
« Reply #12 on: March 11, 2024, 09:58:42 pm »
Thanks kim,thats ok,but any idea how to make the tracks black on a white background,i cant see how to do that,if i print in greyscale it is no good for toner transfer,regards Paul.
« Reply #13 on: March 11, 2024, 10:13:28 pm »
This is what i get printing then scanning in greyscale,bw is worse
Offline jpanhalt
« Reply #14 on: March 11, 2024, 10:14:16 pm »
10 mm between pads may be hard to do, and most important, it is not very practical for breadboards set to 0.1" spacing as is your DIP.  Clue: 1/2 of 2.54 is a prime number.
If you only want to increase the spacing by 2, 3, 4... x0.1 inch increments, then look into a solderable breadboard as provided by SparkFun and others.  I prefer SparkFun versus the much cheaper alternatives, because the connections between holes is only on one side.  That seems pellucidly obvious to me for signals, but apparently didn't meet some other criterion for the vendors of those cheaper boards.  In any event, use short jumpers to expand the 0.1" to any reasonable decimal inch spacing you want, and cut with a Dremel, spherical spur bit the connections that are a problem.
« Reply #15 on: March 11, 2024, 10:43:54 pm »
That pic above was never meant as a working print. Just as an example of what I thought you'd want.
I cleaned it up and printed it to PDF in B&W:
« Last Edit: March 11, 2024, 10:48:21 pm by Kim Christensen »
« Reply #16 on: March 12, 2024, 03:02:03 am »
Thats just the job,thank you.
« Reply #17 on: March 12, 2024, 05:05:04 am »
A good tool for drawing such artwork is Inkscape, which is free and available for all OSes.
For example, PDIP-14 0.4" wide; 1.6mm pins at 0.1" spacing 0.4" wide, 0.7mm traces, 7.62mm×5.08mm pads:
It is not "just" the artwork, it also contains a useful Inkscape template for working in millimeters but with a 0.1" = 2.54mm grid.  The pins and pads are all clones, so changing the top left one changes all of them.  Similarly, the top left four traces are cloned for the other three quadrants, symmetrically.  In the File > Document Properties window, Metadata tab shows you its title and author (me), and License tab shows it is dedicated to public domain via CC0-1.0 license.  As it is SVG format, it is vector graphics; and if you open it in a text editor, or in a browser and View Source, you'll see everything it contains because SVG files are plain text (an XML format, this one using SVG 1.1 specification).
SVG is simple enough to generate from your own script.  For example, you could just generate the pins and pads, and then use Inkscape and the Pen tool (below the spiral) to draw nice old-timey curvy traces.
Offline tooki
« Reply #18 on: March 13, 2024, 10:30:53 pm »
I don’t know what “the mouse goes nuts” is supposed to mean; KiCad doesn’t control your mouse.
Anyway, a simple board like this is the perfect project to learn KiCad or EasyEDA with. (I’d suggest EasyEDA.)
Offline Andy Chee
« Reply #19 on: March 14, 2024, 02:35:06 am »
Do you by any chance have a GPS plugged into your computer? There is a known problem where Windows confuses the GPS data stream for mouse data.
Alternatively, are you operating your transceiver without sufficient RF suppression? Prior to fitting an FT240-31 ferrite in my transceiver USB lead, I would often get random mouse jumps when transmitting 50W FT8.
Offline Hamelec
« Reply #20 on: March 14, 2024, 09:33:31 am »
« Last Edit: March 14, 2024, 09:40:35 am by Hamelec »
Offline vk4ffab
« Reply #21 on: March 14, 2024, 10:16:52 am »
Literally 2 mins to do that in kicad, you really need to learn some of this basic stuff. you can scale it to size.
Online RoGeorge
« Reply #22 on: March 14, 2024, 10:47:09 am »
Also breakout board, can easily turn into break out pins.  ;D
