I'm very sorry for the late response, I should really log in more often as I was not even aware that I was being asked a question here
It seems when I worked on my website I probably ruined
the link. @ManateeMafia: this link is correct, thank you very much. In the mean time the following happened:
1, I (think) I was able to use this circuit to move the "calibration" from my Fluke 87 to the 3478A. "Calibration" because of course the accuracy of the Fluke87 is not enough as a calibration
standard, but at least it made my 3478A useful again for working on hobbyist stuff. And the 3478A accepted the calibration
2, Still missing is the AC calibration part. I used my 3325A instead because I was too lazy to develop the circuit until now.
3, After one hour of continuous operation my initial power supply was overheating and the unit stopped working. I found that a bridge rectifier stopped working because of overheating. I then
decided to add a buck +5V power supply which delivers the high current to the constant current sources. This helped to reduce the power dissipation a lot. The website contains the updated schematic.
Other than that not much happened with this project
I hope I can finish my second 3478A soon, and then I will reuse this circuit again to "calibrate" it. Thanks to all for the interest in this
project. It is really a nice feeling when people are interested in your own work. I will try to log in more often in the future to answer questions in a more closely manner.
