Author Topic: 555 relay switch that triggers when it's not suppose to  (Read 1982 times)
Offline goreTopic starter
« on: January 29, 2016, 08:52:25 pm »
Howdy, folks of the engineering community! I'm having some trouble with this little circuit. It's a simple 555 based relay switch. There's a momentary SPSP switch (*JP1) to trigger the on/off mechanism. SPDT switch (*SW) to set the ON or OFF state of the relay on power on. And a power supply terminal block (*JP2) with a polarity protection diode. It's all there in the schematic bellow.
So here's the problem. Basically it works, but it often triggers with a mere touch of a screwdriver on the contacts of *JP1, for example. Or touching some of the relay outputs does the same thing. It's trigger happy! I need to tone it down a little. It's only suppose to be doing the switching when I press down the momentary switch (*JP1). Why is it so sensitive? ???
« Last Edit: January 29, 2016, 08:55:44 pm by gore »
Offline w2aew
    • My YouTube Channel
Re: 555 relay switch that triggers when it's not suppose to
« Reply #1 on: January 29, 2016, 10:37:56 pm »
Possibly small static charge or noise injection when touching those various nodes.  Consider the following:
Add power supply decoupling.
Consider lowering the value to the two 10K resistors on the THR/TRG line.
Consider adding a small cap 0.1uF or so to the THR/TRG line.
FAE for Tektronix
« Reply #2 on: February 01, 2016, 10:01:00 pm »
Thank you for suggesting that. That seems to do the trick. I've also tried an isolated power supply (a battery), as opposed to a bench power supply. That works too.
Offline Gyro
« Reply #3 on: February 01, 2016, 10:11:45 pm »
Yes, definitely a 100n capacitor to ground on the THR/TRG line, and maybe a series resistor before it too (1k?), otherwise it's effectively an open antenna for spikes.
Edit: Does that capacitor on the CON pin work reliably for defining the power-up state? It might be rather sensitive to slow power supply rise time. The more usual method would be an RC network on the Reset pin.
« Last Edit: February 01, 2016, 10:24:39 pm by Gyro »
Best Regards, Chris
« Reply #4 on: February 01, 2016, 10:41:03 pm »
You are correct. It's not reliable. I've tested it on a bench power supply by switching the channel on and off. It won't define the power up state. Physically removing and reattaching a wire works.
Offline Pjotr
« Reply #5 on: February 01, 2016, 11:01:29 pm »
Have build numerous of this circuit reliably. It's by itself quite elegant. For a normal bipolar NE555 you must decouple the power with at least a 100nF ceramic close to the pins. When switching the thing draws a large cross over current shortly. For the switch use simply screened cable with the screen grounded. Rising R4 to 220K gives a larger debounce/noise margin.
I wouldn't use this reset mechanism with relay contacts. The cont input is noise sensitive and it can also be triggered from noise from the relay then. Better hold the trh/trig input high at power on this way:
« Last Edit: February 02, 2016, 09:48:30 am by Pjotr »
