– Watts are "W" not "w"
– Use "times" sign (×) instead of ex "x".
– In SMD grids are important. So, as far as I can remember, 0.5mm pitch IC "matches" one of the sizes of passives. I don't remember which one.
– You could add via current rating.
– CAPS Value Converter is unnecessary IMO. Only old people don't know what a nF is
– I would add common pitch values (0.35mm, 0.4mm, 0.5mm) to Units Converter.
– You can add how many traces and which width can go between SMD passive of various sizes.
– Add samples of BGA fanout methods
– Maybe a cross-section of a good SMD solder job (SMD passive and IC leg).
– Samples of SMD pad sizes vs. component density
And as a bonus for various expos/conference visitors:
– How many SMD components of a certain size fit into a jar
