Author Topic: DIY Bench Power Supply controlled by an Arduino  (Read 1451 times)
Offline jvankTopic starter
« on: October 18, 2018, 04:23:29 pm »
Hello everyone,
This is my first post here, so please bear with me.
I want to make a bench power supply from scratch. What I mean by that is that I wanted to design the pcb myself. My original idea was to use the LTC3780, and a voltage/current display. But I ran into an issue: I wanted to limit the current, which you can do with an LTC3780, but how can I see what the set current is?
So I scrapped that idea and I thought of using a microcontroller, something like an atmega, and an lcd or oled display. I just have no idea where to start. Does anyone have any tips or things I should look out for?
Thanks in advance,
jvank
Offline anishkgt
  • Country: qa
    • George Hobby
Re: DIY Bench Power Supply controlled by an Arduino
« Reply #1 on: October 18, 2018, 04:27:34 pm »
There are numerous about it. Check out Dave’s video about it. He has explained it and made one.
Www.Georgehobby.wordpress.com
Equipments: DSO104z, Hakko FX888D, Brymen BM869s
Sent from my iPhone using Tapatalk
« Reply #2 on: October 18, 2018, 06:20:38 pm »
Oh yeah I found it lol. Thanks so much!
« Reply #3 on: October 18, 2018, 06:46:44 pm »
Alright so I took a look and I think this is not quite what i want to re-create. The reason is that I want a bigger range of voltage and current.
Would it be possible to just use a different regulator chip, but keep the PWM control? In that case I could use a LTC3780.
Kind Regards,
jvank
Offline anishkgt
  • Country: qa
    • George Hobby
« Reply #4 on: October 18, 2018, 06:52:23 pm »
I would suggest you stray from what is your mind and slowly built it up. You could start off with the component mentioned by Dave and order yours as well.
As you built you would get an idea of what could replaced and then you can built your own version.
