Suggest that you research the specs of your thyristors, gate drive required, dv/dt AK limit, etc.
For me, impossible to comment further without
Thyristor drive circuit,
current and voltage waves at all thyristor gates during fault
Thyristors misfire is symptom of gate noise, wrong drive Z, or inadequate gate drive.
All thyristors with inductive source ( transformers) or load, need a dv/dt limiter, à snubber.
Try 100 ohm, 5 W in series with 50..100 nF, 600 VAC plastic cap rated for snubber service
Bon Soirée
Jon
