Author Topic: 10Mhz OCXO Sine to Square  (Read 21448 times)
Offline BryanTopic starter
Re: 10Mhz OCXO Sine to Square
« Reply #25 on: September 22, 2013, 11:01:55 pm »
I just got my Morion MV89a yesterday, I will just add a OPAMP LM7171, it will not create a square but I don't think you need it to use it for other instruments to use as a reference.
eurofox
Do you know what the output amplitude of the Mv89a is. Specs say ~7dbm
-=Bryan=-
Offline dannyf
« Reply #26 on: September 22, 2013, 11:47:09 pm »
More than 1Vpk.
A guess on my part, :)
« Reply #27 on: September 23, 2013, 01:30:37 am »
I was thinking since 7dbm is around 5mw and using ohms law with a 50 ohm output around .25v, but that is just a wild guess and probably wrong. :-/O
-=Bryan=-
Offline KJDS
    • my website holding page
« Reply #28 on: September 23, 2013, 07:18:01 am »
0dBm in 50 ohms is 224mV rms.
+6dBm will be double that voltage, so +7dBm will be a fraction more, so about 0.5V rms and ~1.5V p-k. Not enough to drive the average logic gate.
Offline hli
« Reply #29 on: September 23, 2013, 09:40:27 am »
The recommended way seems to be using an inverter gate: http://www.pletronics.com/ple/articles/view/401. I used this very circuit recently, but added a DFF divider after the inverter to get a signal with proper 50% duty cycle (my assumption is that the inverter has at least a stable point where it switches).
« Reply #30 on: September 23, 2013, 09:55:31 am »
Look like a neat solution, only thing is the specs call for a peak to peak of 0.8v. Should be ok according to what KJDS posted
-=Bryan=-
Offline dannyf
« Reply #31 on: September 23, 2013, 09:56:12 am »
0dBm in 50 ohms
Do we know that it is referenced to a 50ohm load?
Offline dannyf
« Reply #32 on: September 23, 2013, 09:57:44 am »
That's a self-biased gate ac coupled to the oscillator.
