Author Topic: DIY Lab gear suggestions  (Read 15467 times)
Offline ivan747Topic starter
Re: DIY Lab gear suggestions
« Reply #25 on: June 07, 2011, 11:32:34 pm »
I just got confused. Could you post a link to the schematic of the current limiter you're talking about? Thanks!
The current sense resistor is a very low value resistor (less than 1 ohm) that is in series with the output.
I was talking about the schematic you posted just one post above mine:
I finally found what I was looking for:
http://tgbuilds.wordpress.com/projects/diy-bench-supply/
It's an ATX supply modified with adjustable voltage and current limiting with a display. Cool. Now I only need some function generator and I will save around 150 bucks.
I think it has no limiter. The creator says there will be one on the next version.
