I have been interested in this kit. It looks like it's a well designed, useful and fun little project, plus a good excuse to have a closer look at the Silabs C8051F350 mcu.
So I asked Franky if possible to buy one.
Sure it was, but understandably, no guarantees or support as it's a kit. Sold, as is, with a warning that all the documentation is in Chinese.
Just want to share my experience with this kit. I have no affiliation with Franky, and no discounts or anything.
All the parts included:
Yes, it includes a programmer for the mcu and even a pair of kelvin clips (not very good ones though).
The PCB is good quality with reasonable accuracy, tented vias etc. It will withstand rework if you mess up.
Soldering is not difficult for anyone with at least some basic SMD experience. Smallest components are 0603s and SOT23s. Finest pitch ICs are 0.65mm for the USB/UART controller, the rest are 0.8mm and 1.27mm. All resistors are 0805. Most capacitors 0603. No need for microscope, I use a cheap x10 loupe to check joints when needed.
The only real issue I had during the soldering was that I managed to lose one of the little 0603 LEDs (oops). I was checking the polarity, then noticed my tweezers were a bit sticky, and while cleaning tweezers the LED escaped.
Luckily I have a good selection of 0603 LEDs, so no problem.
The assembly instructions are sufficient, just a BOM in Excel and the PCB with labels in silkscreen. But it's quite time consuming to locate all the components one at a time. It would make assembly much faster if it had included a nice large image of the silkscreen with e.g. color coding based on component type or even small images indicating the location of each item type in the BOM.
One slightly odd detail is that all diodes are marked with a + sign to indicate polarity, opposite of what I'm used to.
Also some of the holes for through hole parts are a bit too small for the solder to flow properly, it's only a minor detail though.
