Author Topic: trouble sourcing display modules (70x40mm)  (Read 272 times)
Offline jpyeronTopic starter
    • PD Inc
« on: May 17, 2022, 06:24:54 pm »
I not sure if there is an efficient way to search for a display module by size.
I am trying to source a display that would be compliant with NEMA WD 6-2016. So the following constraint applies: 33.274x66.802 mm <= size <= 41.275x70.612mm .
At this point none of the other requirements seem to be relevant. Desire high resolution, integrated touch, color.
Help? thoughts?
