Author Topic: DIY - NI-Mh battery charger, no delta-v and no delta-t.  (Read 36805 times)
Offline SilverSolder
Re: DIY - NI-Mh battery charger, no delta v and no delta t.
« Reply #25 on: December 09, 2021, 11:55:16 pm »
The best strategy for charging NiCd or NiMH cells is d2V/dt2 detection. This gives the cells a long life, I'm speaking from experience, my cells have until now survived 1000s of charge cycles without significant degradation. All other strategies that I've seen result in overcharging and damage.
To understand the idea, p.4 of this data sheet helps:
https://pdf1.alldatasheetde.com/datasheet-pdf/view/26117/TEMIC/U2402B.html
Today, you'd let an MCU with associated ADCs run the algorithm.
That seems an interesting principle, haven't seen that before.  Not sure how the low current phase (after d2V/dt2 detection occurs) is handled, is it just a timer or does it still need -dv/dt to stop charging?
Offline vk6zgo
« Reply #26 on: December 10, 2021, 01:44:08 am »
Never ever charge batteries w/o current limiting/regulation
There are "batteries & batteries".
Lead/acid "wet" cells have been charged with simple transformer plus rectifier combinations for decades.
The following users thanked this post: ogden
Offline Avelino SampaioTopic starter
  • Country: br
Re: DIY - NI-Mh battery charger, no delta-v and no delta-t.
« Reply #27 on: January 12, 2022, 03:54:03 pm »
Hi
I finally managed to finish the tests and I'm very satisfied with the results. The font I ordered from banggood met the requirements.
I thank the participants for sharing important information and thus contributing to my learning process.
  • Country: br
« Reply #28 on: January 19, 2022, 05:43:42 pm »
Hi!
I took advantage of the box of an old stabilizer and thus concluded my project.  My eneloop, at the end of the charge, reaching around 1.48v.
