« Reply #25 on: August 20, 2012, 11:04:46 am »
If I was to replace my current Rotel RC-970BX pre-amp (uses NE5532's-Sounds lovely on BBC Radio FM) I would choose this simple discrete design
http://www.passdiy.com/pdf/B1%20Buffer%20Preamp.pdf
And I'd forget about all the MCU stuff. I love the sound of relays clicking though and the contacts are better quality than multipole switches so maybe I could be persuaded.
I've been looking at (planning on putting one together) that preamp for a while now. Have you heard one live? If so, can you give an example of comparison? I've heard so many wonderful things said about it but never actually had an opportunity to have a listen.
Not had a chance to build one yet. It's one of those things that would be nice to try but would be a lot of work. I'm quite happy with my current set up. This is turntable,CD,tuner,PC output feeds the Rotel pre-amp and the pre-amp outputs feed into 2 marchand active filters (2 hi frequency outputs and 2 low frequency outputs). The outputs of the active filters feed into 2 off Rotel RB-970BX stereo power amplifiers. This means each loudspeaker has its own amplifier directly coupled to it (2 Morel tweeters and 2 morel bass-midrange speakers). There are no passive crossovers between the amps and the speakers themselves.
The main weakness with my system at the moment is loudspeaker/room tuning as I cant tweak the response of the speakers easily (no passive crossovers to tune).
It still sounds pretty good though and I'm happy to keep it as it is for now.
« Last Edit: August 20, 2012, 05:31:01 pm by djsb »
Logged
Hertfordshire, UK
University Electronics Technician, London, PIC16/18, CCS PCM C, Arduino UNO, NANO,ESP32, KiCad V8+, Altium Designer 21.4.1, Alibre Design Expert 28 & FreeCAD beginner. LPKF S103,S62 PCB router Operator, Electronics instructor. Credited KiCad French to English translator
