Could you please let me know why the circuit diagram posted won't oscillate , i expected the base to be down when the capacitor is charging, and then the capacitor will discharge when it reach a certain voltage through the transistor, and thus the led would blink , could you please explain what is wrong here ?
Hi
In order to oscillate, a circuit needs to meet certain criteria. There are a lot of ways to look at them and some of it gets a bit involved. One relatively simple way:
You need 360 degrees of phase shift around the loop in order to have oscillation. You also need to have gain at that frequency. With the single capacitor you have in your circuit, you only have 90 degrees. You also have no feedback path from the LED back through the capacitor so the inversion in the collector does not contribute to the phase shift.
So what happens in your circuit:
Power comes on. Transistor base is low.
Current flows into the base and the capacitors
Voltage on the base rises
LED comes on
Voltage continues to rise
Circuit hits it's DC equilibrium point
Nothing more happens.
What happens in an oscillator:
At some point AC feedback cuts in and it's not a simple DC circuit anymore.
Yes, that's still a bit confusing. Oscillators are a bit weird.
What to do to turn your circuit into an oscillator:
Add another R/C
Add another gain stage (transistor)
Close the loop between the stage you have and the input to the new one.
A previous post had a bunch of links to working circuits.
Bob
