Author Topic: DIY pulse generator PG-872  (Read 15124 times)
Offline LivTopic starter
  • Country: by
« on: April 09, 2015, 11:29:44 am »
Features:
• channels number: 2
• internal and external trigger
• pulse width range: 10 ns - 10 s
• pulse width step: 10 ns
• delay range: up to 10 s
• delay step: 10 ns
• period range: 20 ns - 10 s
• period step: 10 ns
• dead time range: up to 10 s
• dead time step: 10 ns
• rise and fall time: 2 ns (5 V, 50 Ohm, 100 pF)
• output level: -5 V - +10 V (Hi Z load)
• output impedance: 50 Ohm
• output level and shift step: 10 mV
• attenuator: 0 dB, -20 dB, OFF
• trigger threshold: -5 V - +5 V
• threshold step: 10 mV
• trigger input impedance: 200 Ohm
• min. trigger pulse width: 10 ns
• interface: USB (optocoupled)
• case type: Z-4A (160 x 140 x 60 mm)
Sine generator SG-642
« Last Edit: April 12, 2015, 01:06:34 pm by Liv »
PSU PSL-3604 Pulse gen. PG-872 Freq. cnt. FC-510
Offline SimonD
Re: DIY pulse generator PG-872
« Reply #1 on: April 09, 2015, 11:57:16 am »
RESPECT !  :clap:
The EPIC Cyclone files ?
How is the progress from your electronic load ... ?
  • Country: by
« Reply #2 on: April 09, 2015, 12:23:52 pm »
Cyclone is loaded from microcontroller FLASH, the configuration file is inside hex.
Work on the electronic load is slow, it is very difficult to design a user interface for graphical LCD.
Offline SimonD
« Reply #3 on: April 09, 2015, 12:31:12 pm »
OK Thanks !
The type of Graphic LCD ?
Keep on the great work !    :-+
  • Country: by
« Reply #4 on: April 09, 2015, 12:38:13 pm »
LCD type - TIC154A (132 x 64 dots, controller - UC1601S, I2C interface). The photo shows the old version TIC151 (blue), which is now no longer available.
P.S. There is a previous version of the generator using 1602 LCD.
« Last Edit: April 09, 2015, 06:42:31 pm by Liv »
Offline OldNeurons
« Reply #5 on: April 10, 2015, 10:24:14 am »
Congratulations !
I really like the professional finish of your devices.
Great job !
  • Country: by
« Reply #6 on: April 10, 2015, 10:28:08 am »
Thank you!
Offline dom0
« Reply #7 on: April 10, 2015, 11:54:43 am »
Interesting design, very smart idea to use a digital line driver and adjust it's supply voltage instead of using a very fast variable-gain (one way or another) amplifier.
