Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
DIY-SMU Project
« previous
next »
Print
Search
Pages:
Prev
1
7
8
9
10
11
12
All
Go Down
Author
Topic: DIY-SMU Project (Read 109551 times)
SuN
Newbie
Country:
Re: DIY-SMU Project
Reply #275 on:
January 14, 2025, 04:09:49 am »
Thanks for sharing!
Now i looking for a high voltage version like 237, I would like base on Dave's DIY SMU and add 237 HV output module.
Can you please give some idea to modify the bias ciricuit from Dave's DIY SMU to High voltage version?
SY
Logged
bateau020
Frequent Contributor
Country:
Re: DIY-SMU Project
Reply #276 on:
January 14, 2025, 06:28:09 am »
plenty ideas here:
https://poormanssmu.wordpress.com/research/
. Also, there are a couple of teardowns of the high voltage versions (237 and 2410/2470) around on this forum and elsewhere.
Logged
SuperMario
Contributor
Country:
Re: DIY-SMU Project
Reply #277 on:
January 15, 2025, 02:35:48 am »
Does anybody know where to get square button covers for this SMU if you are using panel designed by Dave?
Thanks.
Logged
RikV
Regular Contributor
Country:
Re: DIY-SMU Project
Reply #278 on:
January 22, 2025, 10:11:40 pm »
Yes, I do! Mouser has them!
Switch, 6mm Tactile E-Switch TL1105SPF160Q 612-TL1105SP
Rect. Caps, Grey E-Switch 1CDGR 612-1C-GR
Maybe look for anothe keycap (there's awhole series) because the rectangular holes are hard to get ok.
Logged
SuperMario
Contributor
Country:
Re: DIY-SMU Project
Reply #279 on:
January 24, 2025, 08:01:02 pm »
RikV,
Thanks,
Mario
Logged
SuperMario
Contributor
Country:
Re: DIY-SMU Project
Reply #280 on:
January 24, 2025, 08:12:26 pm »
Firmware bug?
I successfully performed force/measure Voltage calibration but having issue with current cal. The problem is that "SOUR:CURR <value>" SCPI command is not working and it seems it is the only one.
I can set current using front panel and it seems to be OK except it needs cal.
Is there any firmware bug that I should know about? I am using code from Dave's page.
Thanks,
Mario
Logged
Print
Search
Pages:
Prev
1
7
8
9
10
11
12
All
Go Up
« previous
next »
Electronics
DIY-SMU Project
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
