I'd like to introduce my DIY Source-Measure Unit SMU project.
http://www.djerickson.com/diy_smu Youtube intro:
https://youtu.be/B26SW3N2zoAIt seems fundamental to have an accurate source for a wide range of voltages and currents, with the ability to measure both. Source and measure are basic requirement for electronics test and measurement tasks and many scientific applications. This functionality should be available at a reasonable cost.
I worked on many DC and AC source / measure instruments for a number of industry leaders (Analogic Test and Measurement group, Teradyne DC Instruments group, Zoll and HP Medical) plus numerous startups and home projects. I always wanted to build a DIY Source Measure Unit: SMU.
Recognizing that this is a challenging project for DIY, now in retirement I finally have the time to develop the hardware, software, controls, and packaging. Fortunately the nerd stars are aligned for such a project. Precision 0.1% and better SMT resistors are readily available at low cost. Precision amplifiers, switches, ADCs and DACs are low cost and easy to apply. Digital isolators and DC-DC power supplies are small and readily available. Hand-built SMT is available and easy to DIY. Single chip CPUs and TFT LCDs with touch are powerful, low cost and DIY friendly.
I pored through old Keithley documents for their 220/240 series sources, and 236 and 237 SMUs and found their general architecture to be flexible and very capable. I suspect that most modern SMUs share the Keithley 236 general architecture.
So after a few years of planning and a year of detailed design, layout, and build, here is DIY-SMU.
Voltage source and measure from tens of microvolts to +/- 150V in 3 ranges: +/- 1.5V, +/- 15V, +/- 150V
Current source and measure from nA to .1 Amp in 6 ranges: 1uA to 100mA
True 4-quadrant operation
Source accuracy .01%
Measure accuracy .005%
Graphic LCD with touch screen
Small, half-rack 2U package
DIY friendly and low cost
It is not complete yet, and I plan to continue the project this winter. PC boards are built and working. An initial GUI is working. It has a basic enclosure. My web page discusses the idea, requirements, design, and implementation. Check it out at
www.djerickson.com/diy_smuThanks,
Dave Erickson
