I want to build my own 18650 pack so i was in need for a spot welder. As aliexpress is full of cheap spotwelders, i preferred to make one by myself as it would be cheap and i wouldn't have to wait for 2 months to start with my project.
After some intense research, say 3 mins on youtube i was already salvaging a transformer from an old microwave. With some 100mm2(2 turns on secondary) wire, arduino and a solid state relay i did a first test. I was not happy with the results. It was more a melting/burning connection instead of a clean spot weld. So i rewired the secondary with a pair of 16mm2(4 turns). Again i was not satisfied with the result. I need about 100-200ms for a good connection and i need to try it multiple times to get a good connection. At this point my material is already very hot and i'm worried it would heat up the cells too much.
After some more research... i found out discharging a large bank of capacitors should give better results. Any suggestions on this idea? What about shorting out a car battery? I know they sell controllers for these applications on aliexpress.
What is the definition of a good spot weld? Is there some simple math to have an idea about the amount of energy needed to do a spot weld? In my case i use 0.2mm nickle strips.
