Hi everyone,
I hope you are doing great. I am looking in the market (google search
) for a PMIC with some probably very specialized functions. We are looking for a single IC solution, but probably a combination of 2 ICs is also workable. Following are the requirements:
1) Solar Panel Input: 18V, 1 - 2A, with MPPT or MPPC (MPPC is what manufacturers refer to "Maximum Power Point Control" which is only setting the voltage of the panel near the MPP)
2) Lithium Ion Battery Management: single cell or muticell, we need it to manage charging, gauging, protection and battery balancing.
Charging: Current in the 1 - 2A range
Gauging: We need to know SoC only, features like SoH, capacity remaining, runtime, are not totally necessary.
Protection: overvoltage, undervoltage, overcurrent, temperature
Balancing: It depends on the multicell configuration, but it is necessary to keep battery safety.
3) DC-DC Converters:
5V, 3A rail
12V, 4 -5A rail
4) Host communications: the PMIC should be able to communicate with a host processor (really and MCU) to get/set parameters (for example, get SoC, protection warnings, charging state, set MPPT voltage, turn on/off DC-DC converters).
Following is an example of the kind of device we need
http://dl.linux-sunxi.org/AXP/AXP223-en.pdf. This has almost everything, with exception of Solar Panel input, and appropriate DC-DC Voltages.
I will appreciate your input, or if anyone has worked on something similar. Our aim is to reduce costs and development time, we know there are single chip solution for each function but, its gonna be more expensive and time consuming.
Thank you guys!
