Hello EEVblogers!
Lately I have been toying with a low power Doppler Radar detector from a police radar detector (Cobra model: ESD-9110)
http://cobra.com/downloads/manuals/ESD9110_manual.pdf Which is a gunn diode oscillator with a waveguide. A gunn diode is an interesting device being that it is constructed of only n-doped silicon. Two heavily n-doped regions at either terminal and a thin layer of material as the middle layer.
http://en.wikipedia.org/wiki/Gunn_diode As electricity is applied, the conductive properties of the middle layer become altered, increasing resistance and preventing conduction as current falls. These diodes are used as oscillators to generate microwaves which can then be tuned with a waveguide. A relaxation oscillator is made by applying a dc voltage to bias the negative resistance, which then creates a zero resistance circuit and then it begins to oscillate. the frequency of the oscillations is determined by the middle layer, and a resonator, such as a waveguide. These are very low power devices, making them suitable for low power applications such as radar detectors.When a high enough voltage is applied, the charge carrier along the cathode becomes unstable which develop slices of low conductivity and high field strength which move from cathode to anode. as voltage is increased more slices are made.
http://academic.cankaya.edu.tr/~basdemir/downloads/ECE358Exp1.pdfI would love to hear your feedback on this topic any Knowledge of this device and its applications is greatly appreciated!
Image references below
explanatory veiw
MY gunn oscilltor
and another
