Author Topic: IR receiver - 4ZP4 KA22 specifications?  (Read 939 times)
Offline raulTopic starter
  • Country: pt
« on: November 18, 2018, 01:51:47 pm »
Hi
A question about a IR receiver component 4ZP4 KA22. I can't find what is and doesn't understand the lettering.
This is from a Samsung AC SH9AWH Model. The LED, power and IR receiver Module.
Someone knows what this designation means? 4ZP4 KA22 (This component is shielded, if the information matters). If i have to choose i go to a 40khz (1 output, 2 - Vcc, 3- Ground).
Thanks
  • Country: pt
Re: IR receiver - 4ZP4 KA22 specifications?
« Reply #1 on: November 20, 2018, 01:58:54 pm »
Any idea? int or whatever?
Thaaks
« Last Edit: November 20, 2018, 02:08:56 pm by raul »
Offline macboy
« Reply #2 on: November 20, 2018, 03:58:00 pm »
Do you need to replace this?
It should be easy to figure out which pin is + power, which is ground, and which is the output signal, just by looking at connections on the PCB.  Almost all IR receivers have an open-collector output (active low). I think Samsung usually uses 38 kHz carrier frequency, but a 40 Khz module would work too.
  • Country: pt
« Reply #3 on: November 20, 2018, 05:05:58 pm »
Yes, is a replace. I know the pins, don't know the frequency. You ar not far for the frequency i though. So i will buy a pair of 38Khz and maybe one 40 for testing and stock proposes.
Thanks for answer.
