Author Topic: Do we still need electrolytic capacitors (for basic decoupling)?  (Read 986 times)
Offline TheUnnamedNewbieTopic starter
  • mmwave RFIC/antenna designer
This might sound like a big of a strange question, but I have spent the last few days diving deep into the concepts of decoupling capacitors, with lots of simulations and modeling.
It got me thinking - Most LDOs have pretty good output impedance up to a few tens of kHz. Past the few tens of kHz, you are already into the regime where big electrolytic caps (especially when combined with trace inductance) are past self-resonance.
So that makes me wonder - are big electrolytics still useful? (I realize some other applications where you have high pulse-loads are a different matter entirely).
Do you still use them? Are you sure there is still a point to using them?
The best part about magic is when it stops being magic and becomes science instead
"There was no road, but the people walked on it, and the road came to be, and the people followed it, for the road took the path of least resistance"
Offline Siwastaja
Re: Do we still need electrolytic capacitors (for basic decoupling)?
« Reply #1 on: April 02, 2020, 01:35:46 pm »
Great for damping resonances and peaking whenever you need to use large values of low-ESR ceramic capacitance - such as input circuitry of most switching converters.
Say, you have 100uF of ceramic capacitance - put a 470uF cheap elcap in parallel. Boom, 100% input overshoot reduced to a few %.
The following users thanked this post: Nominal Animal, I wanted a rude username
Online David Hess
  • DavidH
« Reply #2 on: April 06, 2020, 02:50:23 am »
Just because they are past self resonance doesn't mean they are not providing useful decoupling; their impedance is still low to usefully high frequencies.
They are hard to beat economically when bulk output capacitance is required.  I only see them entirely replaced when long life and high temperature operation is required.
