Author Topic: Do you have abandoned projects?  (Read 12175 times)
Offline schmitt triggerTopic starter
  • Country: mx
« on: November 18, 2023, 04:01:49 pm »
During my over 50 years of electronics both as a profession and as a hobby, I have designed and built countless projects. With very limited occasions, where the project's budget has spiraled out of control or is taking way too long, I always complete my projects. Even if my original estimations proved to be too optimistic, or if the actual performance doesn't meet expectations, I complete the projects. After all, one gains more experience from difficult projects than the ones that work on the first attempt.
Nowadays however, I am on my third abandoned project on this year. After struggling with the troubleshooting or the assembly, I simply lose interest. Since this is a hobby, which is supposed to be a pleasurable endeavor, I don't pressure myself to complete it.
This doesn't mean that ideas don't keep coming, they do and plenty. I look at datasheets, search on the internet, fill my booklet with sketches. But right now I have imposed on myself a "project freeze" until I come out of this lethargy.
Have you suffered such a syndrome?
PLEASE NOTE: I have also posted this question on another forum.
Offline PartialDischarge
Re: Do you have abandoned projects?
« Reply #1 on: November 18, 2023, 04:50:08 pm »
not abandoned, but have a queue of around 12
The following users thanked this post: 5U4GB
Offline dmendesf
  • Country: br
« Reply #2 on: November 18, 2023, 06:06:21 pm »
An engineer never has a problem. He just needs more time.
The following users thanked this post: croma641, Warhawk, shakalnokturn, BadeBhaiya
Offline zapta
« Reply #3 on: November 18, 2023, 07:09:59 pm »
I work on one project at a time and bring it to completion. (hobby).
https://en.wikipedia.org/wiki/Grit_(personality_trait)
« Last Edit: November 18, 2023, 07:11:59 pm by zapta »
Online Kleinstein
« Reply #4 on: November 18, 2023, 07:24:34 pm »
Abondened projects are common in the hobby range, especially in the early stages, when there is not real hardware yet.
In some cases the transition between just a new version / design iteration of an old project and a new one is also not sharp. Another inbetween case are projects that got finished to a certain point and droped part of the origitally planed features - could be lost interest or technical hurdles. E.g. I have a frequency counter with hardware for a RS232 interface, but will likely never implement the interface as the µC ran out of memory and for me not worth it.
I have penty of not finished projects that likely will never get to the end. Some may just not work as planed and with others I lost interrest.
  • Country: mx
« Reply #5 on: November 18, 2023, 08:09:40 pm »
You all bring an interesting point: many times one starts a project to employ an interesting IC or circuit technique. Once that one has understood the concept though, the drudgery of actually measuring and drilling the case holes, cutting, striping and soldering wires, and all of the myriad other details detract from the motivation.
But for me at least, there is something else: I am making more mistakes as I age. I have become more distracted. Not only related to electronics, but to actual life. Some distractions which exasperate my wife. Like when I left a beer can inside the clothes washer. I can't fathom how could I make such a silly mistake. And it was me, because there are only three of us in the household: myself, my wife and a cat. My wife only drinks wine, and I am positive that the cat doesn't drink beer either.
Anyways, those silly distractions have caused me to solder expensive ICs rotated 180 degrees. Yeah, just like a rank newbie. An error which may damage many other things requiring a complete rebuild.
Offline dobsonr741
« Reply #6 on: November 18, 2023, 08:29:50 pm »
I've noticed that treating my hobby project like work, with strict deadlines and fixed goals, often takes away my motivation. Instead, when I let myself explore the idea freely or discover as I progress, the enjoyment returns. Even the initial, less exciting goal becomes just a stepping stone, easily achieved without too much stress.
Online moffy
« Reply #7 on: November 18, 2023, 09:34:13 pm »
I have a number of projects that hang around like ghosts, they haunt me but never quite go away. The ones that are most likely to be finished are necessity driven, the others i.e. 'this sounds like a nice idea' or 'I wish I had this', without necessity driving them take the longest but never quite go away. Recently I have completed a couple of projects that have been floating around for a couple of years, which is quite satisfying, but not in the form originally envisaged. I seem to be only put an old project to bed if I have completed it, no matter how long ago it started, it will continue to haunt me until some sort of resolution. :)
Offline Buriedcode
« Reply #8 on: November 18, 2023, 09:40:59 pm »
Yes, many.  My completion rate is probably <30%.
Things like part availability are rarely the factor - mostly I find its just indecision.  I tend to brainstorm a problem - which is usually only a tiny part of the total project - and come up with 4 - 6 solutions, discount a couple for cost purposes, then can't decide which of the remaining ones to actually implement.
I suspect a few decades ago with much less availability (and choice) of cheap programmable solutions it was easier since there was only a couple of ways of doing things with a large difference in cost/hassle, so decisions were much easier to make.  These days?  I have a choice of tens of different micros, from several manufacturers, different displays, encoder? or buttons?
And then theres feature creep - what starts as a quick test setup to do a frequency sweep for audio filters turned into a full fledged, programmable system - that I have never really used.
Edit: I forgot to mention something that is much more a personality "me" problem than the technology - I really enjoy getting an inital idea and brainstorming, making frantic notes of all the ideas I have for the project, extra features, clever tricks/use of logic or micro's peripherals, then I start testing and prototyping... but then theres the boring part of just building it.  Then I get distracted by yet another idea, and start the creative frenzy with that - whilst the first one was only 10% built.  Rinse, repeat.  I have to actually force myself to finish building things by dedicating an entire day to just that and it seems to be working well, going through my backlog.
« Last Edit: November 18, 2023, 09:45:52 pm by Buriedcode »
The following users thanked this post: shakalnokturn
Offline Stray Electron
« Reply #9 on: November 18, 2023, 09:57:05 pm »
   Same here but lots more than 12.  Partial must be a newcomer to this hobby if he only has 12 projects in the queue.
   Even if I don't finish a project, I usually learn from them.  Often I learn more from my failures than my successes.
Offline mzzj
« Reply #10 on: November 18, 2023, 11:19:53 pm »
Seems like 90% of my projects: Build or test something interesting and once the basic concept is proven move to next project.
I see it more like developing "building blocks" or skills for other projects. Guess basically to learn something new.
In the remaining 5% or 10% projects there is actual, real need to get something done and with a bit of luck I have already needed solution in my mind.
Online RoGeorge
« Reply #11 on: November 18, 2023, 11:25:55 pm »
Proper question would be if I ever finished a project  ;D
Offline retiredfeline
« Reply #12 on: November 18, 2023, 11:49:37 pm »
All the time. Some are abandoned even before I think of them.  :-DD
Offline CaptDon
  • Country: is
« Reply #13 on: November 19, 2023, 01:09:03 am »
Do ex-girlfriends count?? I have one project to finish. It rotates a Yagi antenna for 2-meter transmitter hunts and field day. I have a P.P.I. sweep display and it draws the typical 'goldfish' yagi pattern on the display with the major lobe point toward the source. I sold the 6 element antenna years back and need to replace it. The display has been updated to digital storage, prior to that I was using a 5ADP7A radar C.R.T. for the display. I realized my time on this earth grows shorter and I have given away most of my test equipment and parts inventory and I still have far to much! Just concentrating on providing quality sound for local bands and playing in a band and doing some ham radio stuff. Also decided to try to learn some C++ but that may eventually become an abandoned project as I have no real need for it, just curious!!
Offline coromonadalix
« Reply #14 on: November 19, 2023, 01:15:19 am »
yes  in the times when   mini pc's where put in the cars as audio / video / gps systems
centrafuse and other related car pc softwares, i have tons of centrafuse versions, usb gps antenas receivers ... mini / micro pc's   7"  Liliput touch screens  ...  all now sits in a box
android auto or carplay IS the new tech  loll
Offline Dan123456
« Reply #15 on: November 19, 2023, 01:26:42 am »
Absolutely! I have put projects on hold at times but that is usually because I don’t understand how to make it work or am not confident I know how to do it safely yet (I still consider myself a newbie and am still learning) :P
I usually try not to completely abandon projects as figure they are good learning opportunity (even if I fail miserably) but occasionally I find the exact thing I was planning to build at a price I just can’t say no to so end up just buying it rather than building it  :P
Offline Bud
« Reply #16 on: November 19, 2023, 01:37:10 am »
Not abandoned. But postponed. Some for 20 years   :-DD
The following users thanked this post: schmitt trigger, shakalnokturn, robert.rozee, Dan123456
Offline coppice
« Reply #17 on: November 19, 2023, 02:31:05 am »
Some until the technology looks ludicrously outdated, and most of the parts needed are long out of production, but always just deferred. I know that syndrome well. :)
Offline Terry Bites
« Reply #18 on: November 20, 2023, 06:12:28 pm »
Too many. I'm a great starter and a terrible finisher.
Offline gbaddeley
« Reply #19 on: November 22, 2023, 09:19:58 pm »
To me, abandoned means the project was started, but will not ever be completed. Eg.  Components, case etc were torn down / repurposed. I have projects that have taken multiple years to complete, after completing other projects in between. Others are sitting in boxes, waiting for the time / motivation to finish them off. I also had ideas for nice projects, but took a realistic decision— I will never have time to do it, so there is no point doing sims or gathering components.
Glenn
Offline Sacodepatatas
« Reply #20 on: November 22, 2023, 11:15:08 pm »
Don't feel bad.  I have been flipping ICs, wiring, letters .... for decades.
If you are concerned, I would get tested.
Every EE knows there is an invisible goblin that likes to play annoying games like flipping elcos, diodes, wirings, etc. You can two or threefold take a look on everything being ok, but once you switch on and then magic smoke appears, you realize that this little goblin striked again.
The following users thanked this post: Vovk_Z
Online SiliconWizard
« Reply #21 on: November 23, 2023, 05:50:35 am »
That's almost a FAQ. ;D
I think we've all been subject to this issue, more or less. Ultimately, it seems to come from two major factors: first, not having clearly defined what the goal was (if we don't exactly know what we consider the end of a project, we can obviously never know when it's done, so we end up losing track), and second, the oh-so-terrible: procrastination.
Yep, procrastination is what makes us go from one project to the next and leaving the previous one behind, because starting something new is more immediately rewarding. It's what makes us lose interest.
Now, when the goal was not clear from the start and there is no big pressure (like external pressure), moving on to something else can be beneficial - makes us learn new things. But procrastination is always there, lurking. It's an absolute plague.
Offline TrickyNekro
  • Country: gr
  • Drinking Frappé on the way to Isomnia!
    • Youtube channel, electronics and more ;-)
« Reply #22 on: November 23, 2023, 07:12:04 am »
I wouldn´t call them abandoned, just terribly postponed.
Problem is that when your hobby is your job, usually weekends are used for something else rather than sticking in front of a screen.
Although for some reason, I still keep throwing money at them, here or there, probably part of dealing with my bad consciousnesses.
And when I get to actually do some work on them, I try to not start another one, unless one of the old ones are ready first, unless it´s
something that will not take longer than the weekend. But this has also a big potential to fail... Life´s not easy...
If you are an engineer and you are not tired...
You are doing it wrong!
Online dietert1
  • Country: br
    • CADT Homepage
« Reply #23 on: November 23, 2023, 09:01:25 am »
I think the industrial mantra of "finishing projects" isn't completely honest. If you think about how many versions of MS windows already exist, it's easy to understand that the concept is a marketing fake. Real achievements take years or decades to arrive at what we nowadays call IP. And the process to arrive there doesn't really happen in one head but in many. Also it doesn't happen inside one enterprise but in many. There's another contradiction: How can something public be IP?
Regards, Dieter
Offline SuzyC
« Reply #24 on: November 23, 2023, 09:22:52 pm »
Easy.  IP in public.
" target="_blank">
