Author Topic: Do you recognize this part?  (Read 2204 times)
Online ali_asadzadehTopic starter
« on: July 11, 2019, 08:49:53 am »
This is one of the cheapest 7w led lamps(230Vac) that I could have found, I was curious what is inside, it's just a MB10F bridge a 47 ohm series resistor and a 390 ohm series resistor and 7 1W led, there is one 3 pin package inside the loop, is it a constant current one!? do you recognize it? it's marking is J2101S, is it something like LM317 a cheap chinese version?
ASiDesigner, Stands for Application specific intelligent devices
I'm a Digital Expert from 8-bits to 64-bits
Offline JackJones
Re: Do you recognize this part?
« Reply #1 on: July 11, 2019, 09:24:22 am »
It does look like a constant current driver, they usually are. I did find this page about it:
https://www.alibaba.com/product-detail/Factory-good-quality-3W-TO-5W_62066419259.html?spm=a2700.7724838.2017115.1.bac05b1d4KfoSN
Offline amyk
« Reply #2 on: July 11, 2019, 12:07:42 pm »
Yes, it's a current regulator. See the YouTube bigclivedotcom channel for lots of videos of LED lamps with this style of circuitry.
7 LEDs in series seems a little low, unless each one itself has multiple die in series inside, because linear regulators dissipate a lot of heat and are thus usually used for strings of >200V for a 240V line voltage.
« Reply #3 on: July 12, 2019, 08:32:24 am »
Thanks :D
