Author Topic: Do you recognize this puppy?  (Read 2042 times)
Offline ali_asadzadehTopic starter
« on: August 24, 2017, 12:59:44 pm »
Do you know this part?  ;)
ASiDesigner, Stands for Application specific intelligent devices
I'm a Digital Expert from 8-bits to 64-bits
Offline CJay
Re: Do you recognize this puppy?
« Reply #1 on: August 24, 2017, 01:01:15 pm »
some kinda three phase IGBT pack probably, there'll be a part number somewhere if you desolder it
The following users thanked this post: ali_asadzadeh
« Reply #2 on: August 24, 2017, 01:06:52 pm »
Thanks, who made these? maybe by the size we can recognize it?
Offline noidea
« Reply #3 on: August 24, 2017, 02:37:40 pm »
The part number will be on the underside you will have to de solder it or cut it off the board to have a look.
Offline daqq
  • Country: sk
    • My site
« Reply #4 on: August 24, 2017, 03:44:30 pm »
Looks like this:
http://uk.farnell.com/fairchild-semiconductor/fsbb20ch60f/ipm-igbt-20a-600v-spmca-027/dp/2322642
That said, more manufacturers make similar ones. Without desoldering it and looking at the number you can't be sure.
Offline shved
  • Country: ru
« Reply #5 on: December 19, 2019, 11:22:29 am »
Filter through Infineon, IR, etc. catalogs, you will find it. I've seen amateur VFD project using those modules in some Russian forum, and i don't remember witch one. I remember that microcontroller firmware was closed source and guarded by the author, so i wasn't interested any more.
Hope that helps.
« Reply #6 on: December 19, 2019, 01:42:48 pm »
Shved, that post was from over 2 years ago, it's unlikely the OP still needs the information.
Do you have any info?
Offline shved
  • Country: ru
« Reply #7 on: December 19, 2019, 01:55:29 pm »
Unfortunately i can't find the forum thread with DIY VFD. But I've searched some Russian sites and found possible match: FSBB30CH60 .
https://www.chipdip.ru/product/fsbb30ch60
It seas that this is obsolete component.
I think you should browse some more shops and catalogs.
