Author Topic: Do you recognize this transistor?  (Read 1308 times)
Offline ali_asadzadehTopic starter
« on: September 28, 2023, 05:03:23 pm »
Hi
Do you recognize this transistor? I can not find any thing on C8918
ASiDesigner, Stands for Application specific intelligent devices
I'm a Digital Expert from 8-bits to 64-bits
Offline TimFox
Re: Do you recognize this transistor?
« Reply #1 on: September 28, 2023, 05:18:19 pm »
I believe "8918" is the transistor manufacturer's date code:  18th week of 1989.
The "1848-4394" is the "private" code assigned by the instrument's manufacturer for his order with the transistor manufacturer.
Is this an -hp- unit?
« Reply #2 on: September 29, 2023, 07:06:22 pm »
Thanks Timfox for the tip, do you have any datasheet or suggestion replacement for this part?
My customer sends it, I should ask them about it to see if it's hp,
Offline TimFox
« Reply #3 on: September 29, 2023, 07:08:46 pm »
I looked for that eight-digit number, but could find nothing useful.
If you know the manufacturer of the unit (the first four digits may not be -hp-), you might find an appropriate index online for that company.
Offline coppice
« Reply #4 on: September 29, 2023, 07:18:13 pm »
PRX should be Powerex. Consider that any semiconductor marked C plus 4 digits might mean 2SC plus those 4 digits. However, in this case I think Tim is right. 8918 is the date, and 1848-4394 is probably a customer specific code for a customised part. HP being the likely candidate.
Offline floobydust
« Reply #5 on: September 29, 2023, 07:18:55 pm »
Thread is not useful without a model # or make
Offline schmitt trigger
  • Country: mx
« Reply #6 on: September 29, 2023, 07:26:00 pm »
Many electronic designs employ catalog semiconductors screened to a particular performance specification. If you are a large enough customer, semiconductor vendors will gladly do that for you and write on the transistor your own house number.
I even worked for a company which purchased close to 100,000 power transistors per week. In that instance, the vendor actually tweaked the process of a catalog item in order to better meet our specific requirements. And obviously, it had a house number.
