Hey folks.
I'm designing a circuit board for a flight simulator that's intended to trip an array of approximately 64 low-current circuit breakers, and the breakers themselves have 0.250" blade ("quick disconnect") terminals on the back, spaced 17mm apart. Below is an excerpt from the datasheet with the dimensions and a picture of one of the breakers.
I was curious if a socket exists to allow me to plug these directly into a PCB (similar to a relay socket), since this would be a far better alternative to running a rat's nest of wires behind a panel. Unfortunately I haven't come across anything that would accommodate these. Just curious if anyone has any ideas or pointers? Searching the distributors (Digi-Key etc.) is a bit of a mess when it comes to looking for a specific type of connector that you don't know the name of.
Thanks!
