Author Topic: Electronic load analog part  (Read 281 times)
Offline electros6
« on: May 18, 2021, 04:11:48 pm »
Hi guys,
            I tried to build a Electronic load . I have attached the analog part of the schematic. My question is how do i calculate the damping factor of the analog part and damping resistors for pulse load.
                                            Thanks in advance
                                            Baskaran
Offline Zero999
  • 0999
Re: Electronic load analog part
« Reply #1 on: May 18, 2021, 04:25:45 pm »
Why are there so many op-amps? Normally only one is required to ensure the voltage across the sense resistor, matchs the reference. If the reference voltage is too high, then add a potential divider to attenuate it.
Offline Vovk_Z
  • Country: ua
« Reply #2 on: May 19, 2021, 01:38:00 am »
What is a 'damping factor of an analog part'? And what is a 'damping resistor'?
