A LM317 in current limiting mode is my go to solution for this and easily junk-boxable. I would never use a resistor for a high power LED unless I heavily derate it. Assuming you don't mind the inefficiency. Just a lm317 and a 1.2 ohm resistor will do for a one amp current limited supply.
Use your lab power supply in constant current mode set to one amp to test what voltage it is roughly going to use for that too see what size heat sink you will need for the LM317. (Vin - Voltage shown on power supply)*1Amp gives the watts that the LM317 will dissipate, which won't be that much heat sinking needed relative to what your LED will need anyway.
Thanks, so hooking up my 12v to LM317/1.2ohm and straight to my LED will be all?
And I kind-of blew my only bench power supply 4 months ago, it was a nice astron 15 amp 34 volt analog one, but I blew it trying to charge a 150F supercap and scrapped it for parts.
Yes, hook it up in the 'current limiting' configuration as shown in the data sheet. You can use a multimeter to measure how it is working. just measure the voltage across the led while it is lit to see what voltage it is getting or the voltage accross the resistor as in, hook your voltmeter leads to each side of the resistor withe the led on and current = voltage shown/reistor value. I recommend using the voltage method rather than directly using the amps feature of your multimeter because it won't blow your meter (well, just its fuse if it's a well designed meter) if you accidentally wire it up incorrectly.
If you happen to be reading laser/led forums and see people complain that the lm317 configuration "wastes power" because it has a resistor in it, ignore that. it's complete rubbish and somehow gets repeated a lot and people end up with convoluted and worse supplies that waste the same power and wonder why their expensive laser LEDs burn out. A current limiting linear supply will pass as much power as is needed to get the desired current, if some is dissipated in the resistor it just means the regulator will dissipate exactly that much less to make up the difference. If anything you improve things by split the heating between a resistor and a lm317. for you, 1 amps through 1.2 ohms = 1.2 volts, power = volts * amps so your resistor will dissipate 1.2 watts. If you don't have a power resistor, you can just use multiple resistors in parallel, as in, 3 3.6 ohm 1/2 watt resistors in parallel or 5 1/4 watt 6 ohm ones. That is very conservative, when splitting resistors you can actually dissipate a lot more power than simply summing the wattages because the resistors are separate from each other and have more surface area for air to flow between them. If they are not getting too hot to touch, you are okay.
I am surprised you were able to blow your bench power supply, good ones are designed to be bulletproof. Actually it looks like the astron are not lab grade power supplies, but meant to power RF and audio equipment so a different beast that won't have the protections of a lab supply and shouldn't be used for experimenting.
You can probably use its case/meters/transformer to make a traditional kit lab supply with your extra LM317s.
