Author Topic: Help USB Thermal Printer  (Read 1202 times)
Offline djluckTopic starter
« on: November 15, 2014, 08:19:07 pm »
Hello,
Am am trying to install on my mini pc (Intel Celeron 1037u Dual Core Mini PC) a 80mm Thermal Receipt Printer .
My mini pc is running on debian operating system. As I read on the internet you must first instal "cups", but unfortunately I am unable to accomplish this.
I've been trying the process described here (but as I said without luck ): https://wiki.debian.org/SystemPrinting
The error that I get is this:
  apt-get install cups
  Reading package lists... Done
  Building dependency tree
  Reading state information... Done
  Some packages could not be installed. This may mean that you have
  requested an impossible situation or if you are using the unstable
  distribution that some required packages have not yet been created
  or been moved out of Incoming.
  The following information may help to resolve the situation:
  The following packages have unmet dependencies:
  cups : Depends: libslp1 but it is not installable
  Depends: poppler-utils (>= 0.12) but it is not installable
  Depends: ghostscript (>= 9.02~) but it is not installable
  Depends: ssl-cert (>= 1.0.11) but it is not installable
  Depends: cups-filters but it is not going to be installed
  Recommends: foomatic-filters (>= 4.0) but it is not installable
  Recommends: printer-driver-gutenprint but it is not installable
  Recommends: ghostscript-cups (>= 9.02~) but it is not installable
  E: Unable to correct problems, you have held broken packages.
Can somebody help me with my problem or propose an alternative??
Thank you in advance, cheers,
Djluck  :D
« Last Edit: November 18, 2014, 08:44:46 am by djluck »
