Author Topic: SD vs SDHC  (Read 5180 times)
Offline alank2Topic starter
SD vs SDHC
« on: July 28, 2016, 10:52:54 pm »
For those of you who have worked with SD/SDHC, what do you have to do different for a SDHC as far as the interface/communication protocol is concerned?
Offline exmadscientist
  • Technically A Professional
Re: SD vs SDHC
« Reply #1 on: July 29, 2016, 02:16:17 am »
SDHC is little different from plain SD, as long as you have FAT32 support (which you probably do). The main change is that the initialization sequence is slightly different, accounting for the different representation used for card space.
SDXC is when things start to get more troublesome, as it brings mandatory exFAT support into the picture.
Online NiHaoMike
    • Facebook Page
Re: SD vs SDHC
« Reply #2 on: July 29, 2016, 04:54:10 am »
You could reformat the card to FAT32 or some better filesystem like ext4.
Re: SD vs SDHC
« Reply #3 on: July 29, 2016, 05:50:01 am »
Sure, but if you do that, then you've got an oddball card that doesn't actually comply with the SDXC spec, which mandates exFAT. You probably won't be able to read it in anything but your device (and, probably, a Linux box). That's all good and well for a one-off or personal project, but users will hate it -- and rightfully so.
Offline Berni
  • Country: si
Re: SD vs SDHC
« Reply #4 on: July 29, 2016, 06:26:36 am »
Just a slight difference in initialization to let you know the card is SDHC because they use sector addressing rather than byte addressing. This tweak lets them address 512 times more memory.
Most modern FAT32 libraries that support SD also automagically support SDHC
Offline voltsandjolts
Re: SD vs SDHC
« Reply #5 on: July 29, 2016, 09:31:06 am »
It is disappointing to see the SD Card Association mandate exFat for SDXC which is yet another propriety and patented Microsoft file system.
Why could they not have used an open standard free for all to use, helping all consumers who use SD cards. Instead they choose to be part of the tech extortion cartel which puts toll gates in the path of interoperability.
Offline Kilrah
Re: SD vs SDHC
« Reply #6 on: July 29, 2016, 10:05:55 am »
Name an open and widely implemented format that allows for those sizes and doesn't have a 4GB filesize limit? Oh, right...
Re: SD vs SDHC
« Reply #7 on: July 29, 2016, 10:34:20 am »
Well, there is f2fs or ext2 which are both open standards and suitable for flash storage.
But my point is, if existing standards did not suit them, the SD Card Association could have developed their own open standard for SDXC and actively helped consumer product interoperability. Instead they chose to use exFat which was designed to be patented and extract royalties, not to be technically novel or move technology forward in any meaningful sense.
« Last Edit: July 29, 2016, 10:36:27 am by voltsandjolts »
Offline Kilrah
Re: SD vs SDHC
« Reply #8 on: July 29, 2016, 10:45:09 am »
Neither of those are properly supported on the Windows computers that 95% of SD card users are going to use to read them.
But the SD Card Association's own purpose is precisely to market patents and extract royalties!
These associations are created by the big technology companies precisely as joint ventures to market their respective technologies. Someone did R&D to develop a card format, someone did R&D to develop memory that can fit in there, someone did R&D to develop a file format that's suitable and easy to implement for said companies and the customers etc... put that all together, market it, and share the profits to recoup the investments.
Re: SD vs SDHC
« Reply #9 on: July 29, 2016, 11:09:45 am »
And neither was exFat before it was 'invented' and pushed down our throats via Windows Update. Any new open format could have been delivered in the same way and in fact could have seen much wider adoption (by virtue of being open).
And I'm fine with that, as long as it's related to the hardware of the device. That's what I pay for when I buy a physical SDXC card. Maybe if they had been more helpful and used an open file system format they would sell more SD cards.
Probably two people - a lawyer and an accountant.
Offline Kilrah
Re: SD vs SDHC
« Reply #10 on: July 29, 2016, 11:35:14 am »
exFAT existed 3 years before SDXC cards were announced. Why would you work on / develop support for an open standard when you've got something appropriate that's there, and fits the commercial goals?
:-DD
Pretty much everything that has a use for exFAT already supports it and has for quite a while. Someone who needs it for a commercial product can afford the licence with no problem, they already have to pay for one for the use of SD in the first place anyway.
The only ones who might have trouble are hobbyists, and of course they don't care the slightest about those, it's insignificant.
Re: SD vs SDHC
« Reply #11 on: July 29, 2016, 11:49:42 am »
Hah, of course it did, Microsoft getting ready to sell it's wares!   :palm:
And who pays for that, the consumer of course  :-DD
And then you pay for the app to get exFat on your phone, then your SDXC doesn't work in your NAS...all a PITA because of a file system that has less merit than many free and open solutions.
It would just be nice to buy an SDXC card that works interoperably across all my devices - that's what SD should be about, not just a memory stick for Windows.
Offline bson
Re: SD vs SDHC
« Reply #12 on: July 29, 2016, 02:59:52 pm »
I doubt hobbyists have any problems.  If you implement an open-source exFAT and put it up on github for instance there's no problem - you just can't sell products with it.  You can use it to your hearts content for your own purposes, or with friends, or the good people here at eevblog or elsewhere.  As long as you don't try to sell it there's no problem.  And if you do decide to sell it... just go license the rights.  It's no big deal any which way.
My main beef with SDXC is that there's no single patent pool that can be licensed using uniform boilerplate terms, unlike say MPEG LA.  Instead you need to figure out on your own all the random little things you need to license, then negotiate with each of the owners individually.  Miss something and you're now in the position of negotiating a posteriori which weakens your position.
« Last Edit: July 29, 2016, 03:02:16 pm by bson »
Offline Kilrah
Re: SD vs SDHC
« Reply #13 on: July 29, 2016, 03:07:40 pm »
Sure, what I meant was that as far as I knew an open source implementation didn't exist, so if you wanted to use exFAT in your microcontroller or FPGA-based gizmo you might have been in for a wild ride reverse-engineering and implementing it.
But a quick search shows that there's already an implementation coming from Samsung (which I assume works, since my Samsung things are perfectly happy with exFAT media :D ) so it's all a matter of wrapping it properly, no issue.
https://github.com/dorimanx/exfat-nofuse
Re: SD vs SDHC
« Reply #14 on: July 29, 2016, 07:12:33 pm »
Sure, I just wish everybody could use it without problems.
If the cost of driver development was factored into the actual hardware cost of the SDXC card and thus a reference driver implementation made openly available, interoperability for the consumer would be much improved.
Online NiHaoMike
    • Facebook Page
Re: SD vs SDHC
« Reply #15 on: July 30, 2016, 05:39:57 am »
Licensing issues aside, I also remember reading that at least on Raspberry Pi, exFAT is significantly slower than ext4.
Maybe a workaround is to ship the product without the driver, then have the user download it during setup? But I suggest simply refusing to support such garbage if you can get away with it.
BTW, Android 6.0 devices have the option to reformat the SD card with ext4 in order to allow installing apps on it. Something to do with the file permissions, which neither FAT32 nor exFAT support to the required degree.
Offline David Hess
  • DavidH
Re: SD vs SDHC
« Reply #16 on: July 30, 2016, 05:07:31 pm »
UDF
But as pointed out above, no royalty free standard was going to be approved with Microsoft calling the shots even if they had to invent a new filesystem.  If UDF had been used, Microsoft would have made sure Windows did not support it on removable media.
As far as Windows compatibility, with Microsoft's continuing Windows 10 screw ups that is becoming less important as time goes on.
Re: SD vs SDHC
« Reply #17 on: August 29, 2019, 12:21:29 pm »
Well, stone the crows.
Microsoft is making exFAT available for use in the Linux kernel.
https://www.zdnet.com/article/microsoft-readies-exfat-patents-for-linux-and-open-source/
