For a 100MHz sine wave. But you need to look at rise time.
OOohh... Oh that´s very clumpsy of me, you are very correct.
Usually I assume 9th harmonic to have enough power to show somewhere ( which for many is an overexaggeration and would rather
only check the 7th harmonic, but that´s another discussion for another day ), which is a wave of 33cm or 330mm of length
λ/4 would be 82,5mm and usually shorter lines than λ/10 do not really interact much. So any trace shorter than 33mm,
would pretty much not create much trouble.
Traces from IC to IC are about ~9.5mm so that would not create much trouble, I shall only try to keep total length
of the traces near under 33mm and I should be alright.
Thanks! Your comment was more eye opening than you think!
