Author Topic: Dressing wires nicely  (Read 2212 times)
Offline tkamiyaTopic starter
« on: June 06, 2019, 06:50:50 pm »
I hate messy wiring.  Running wires all over perf board or interconnects in chassis makes work so much more difficult.
In old days, (in Japan), there was this stretchy nylon(?) twine that self-cinch and stays put.  Even older says (in US), kits like Heathkit provided bundled wire dressed like this already with fibrous yarns(?).
Can I still buy those?  I don't want to use zip ties.
Offline bsudbrink
Re: Dressing wires nicely
« Reply #1 on: June 06, 2019, 07:33:41 pm »
The term that  you are missing is "lacing".  I'm sure I remember reading a long thread somewhere on EEVblog about it, but I can't seem to find it now.  Anyway, many people (myself included) recommend waxed dental floss (unflavored).  The thicker stuff, not the "fine".
A couple of other links:
https://makezine.com/2009/07/28/lost-knowledge-cable-lacing/
https://en.wikipedia.org/wiki/Cable_lacing
« Last Edit: June 06, 2019, 07:38:39 pm by bsudbrink »
Offline soldar
« Reply #2 on: June 06, 2019, 08:04:37 pm »
The reason lacing was used in ye olden days was not to make it look good but because shaped wire harnesses were built beforehand and were one more part in the final assembly.
Offline edpalmer42
« Reply #3 on: June 06, 2019, 08:08:14 pm »
If you search the auction site for < "lacing twine" > you'll find what you want.  I've seen more listings in the past, but there are only a few now.  Note that the quotation marks are important!  If you leave them out, you'll find a whole different kind of lace!   >:D  You've been warned!
Another way to control wiring is with nylon spiral wrap.  It's relatively easy to find in a variety of sizes and colours.  It's easy to pull wires out of the bundle wherever you want.
Ed
Offline MarkF
« Reply #4 on: June 06, 2019, 08:32:25 pm »
This is how I was taught to tie the knot.
However, my company only does the initial knot and trims it.
They don't do the running knot.  Just individual knots separated about 4"-6" on long cables.
The spacing is a judgement call based on what and where your cables are.
I have a bunch of the waxed lacing cord but you could use waxed dental floss for personnel projects.  (Flavor is your choice  :-DD)
https://www.amazon.com/Waxed-Lacing-Tape-Spool-Black/dp/B005PQRLYC
« Last Edit: June 06, 2019, 08:35:23 pm by MarkF »
Offline langwadt
« Reply #5 on: June 06, 2019, 08:49:01 pm »
still done, https://www.aircraftsystemstech.com/2017/05/wiring-installation.html
Offline mariush
« Reply #6 on: June 06, 2019, 10:04:45 pm »
You could 3D print wire combs or buy existing...
See for example : https://www.ebay.com/itm/PC-Cable-Comb-Dresser-Insert-Version-F-3-0mm-Wire-3-3mm-Cables-Black-Clear-/132001146293  or https://mainframecustom.com/shop/cable-sleeving/cable-combs/mainframe-customs-stealth-cable-combs/lc-stealth-cable-combs/
You could make them from two parts , with one that has some plastic clips on the corners and one that has some holes where the other part would have holes.... when you bring them together the clips go inside the holes locking the two plastic bits in place until you press on the clips to release... or whatever, some other locking mechanism
And also what's wrong with regular ribbon cable... you could buy spools of ribbon cable and cut bands as needed
ex 150 meters of 50 conductor ribbon cable: https://www.digikey.com/product-detail/en/3m/3365-50/3M155838-500-ND/3867406  or multi-color 64 wire 92 meters: https://www.digikey.com/product-detail/en/assmann-wsw-components/AWG28-64-F-300/AE64M-300-ND/655751
The above are thin guage, but there's cables as thick as AWG14, or with transparent insulation .. ex 300 meters of 4 wire AWG20 ribbon : https://www.digikey.com/product-detail/en/cicoil/969M101-20-4/CI20D-1000-ND/3524430
« Last Edit: June 06, 2019, 10:08:12 pm by mariush »
Offline ChristofferB
  • Chemistry phd student!
    • My channel:
« Reply #7 on: June 06, 2019, 10:05:15 pm »
I lace with that waxy black thread used for leather work. It works really well, since it kinda clings to itself, but it's admittedly a bit more bulky than real lacing thread.
I still think short (2mm or so) lenghts of heat shring every 10-20 cm looks pretty good given the ease of that approach.
--Christoffer //IG:Chromatogiraffery
Check out my scientific instruments diy (GC, HPLC, NMR, etc) Channel: https://www.youtube.com/channel/UCZ8l6SdZuRuoSdze1dIpzAQ
Offline David Hess
  • DavidH
« Reply #8 on: June 07, 2019, 03:11:40 am »
Waxed dental floss can work as lacing if you need something immediately.
For shorter lengths with fewer wires, I often just braid the wires together.
Offline BurningTantalum
« Reply #9 on: June 07, 2019, 12:09:43 pm »
The waxed lacing cord that I used when I first started work was made by a company called 'Barbour', and I always assumed that it was the same people that made the waxed waterproof jackets. We made the prototype 'looms' on ply boards using 'Stellite' headless nails for the corners and turning points. When the loom was laced up it could be pulled off the nails complete and laid aside ready for installation in the equipment. In production the same technique was used but the ply boards had a grid of threaded inserts, and the pins were headless and threaded at the other end so could be screwed into the board in the nearest insert to the design layout.
Happy memories (actually I hated it...)
BT
« Reply #10 on: June 09, 2019, 04:27:58 am »
Hum....  I was looking for something thinner....
What I see on eBay, I could probably find them at Home Depot or craft shops. I'll visit a few and see what I can dig up.
Offline MarkF
« Reply #11 on: June 09, 2019, 05:54:01 am »
Even dental floss is too thin unless you are lacing bundles inside a small enclosure.
There is always the chance that thin lacing cord will cut through the insulation and cause a short.
As others have said, you want lacing cord around 1/8" or 2-3mm wide.
If you end up with something like dental floss, don't pull it too tight.
Offline David Hess
  • DavidH
« Reply #12 on: June 10, 2019, 05:06:48 am »
Thin waxed cord is sometimes used in upholstery work.  It might be found at a fabric or craft store.  I have also seen some kind of thin tacky clear plastic monofilament used for cable dressing.
But I suspect waxed lacing cord is the best option.
