Author Topic: Drive a sharp LCD by TOSHIBA chip  (Read 889 times)
Offline wiwiwiTopic starter
  • Country: sg
« on: August 29, 2019, 10:10:57 am »
Help Please,
Now I have a sharp LCD (model: LS055T3SX05) and a THOSHIBA chip (TC358870XBG).
But first of all, I want to light up the LCD. From what I read there are three pins (LED+, LED-, LED_PWM) related to backlight.
I apply 5v to LED+ with 0v to LED-, for LED_PWM I am using the 3.3v blue pill (arduino) to produce pulse. However, Backlight is still not working......
anyone can help? appreciated!!!!!
 |O |O
  • Country: sg
Re: Drive a sharp LCD by TOSHIBA chip
« Reply #1 on: September 03, 2019, 05:06:44 am »
help pls!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Offline oPossum
« Reply #2 on: September 03, 2019, 05:17:19 am »
Backlight is 6S2P so it's not going to run on 5V.
  • Country: sg
« Reply #3 on: September 11, 2019, 06:52:58 am »
But weather this LCD need to be driven by code (like power on sequence) with a MCU or direct voltage can light up the LCD?
I found there is a information say "POWER ON sequence, power off sequence, video mode sequence" in the lcd document, so that I wonder this lcd need MCU to drive.
Offline ealex
« Reply #4 on: September 11, 2019, 02:10:29 pm »
it would help us if you attach a datasheet fro the display - I've tried looking for it and it does not seem readily available.
the backlight has 6 leds in series and no back-light driver
you'll need to supply at least 18V, current limited to ~ 20mA for start
about how to initialize the display - no clue without a data sheet
  • Country: sg
« Reply #5 on: September 13, 2019, 01:46:32 am »
Of course, here we go.
I am quite confused weather the mipi lcd can power on backlight by supplying voltage directly without any code or power sequence?
thanks, bro.
