I didn't want to respond any more, because it just got too antagonistic and you seem to feel me ignorant. With a little help from Ian maybe I'll might get through. What I said had nothing to do with it being a proper kill switch or not, it just had to do with how to cut power to the motors. Apart from Ian two more people suggested just using the ESC themselves to cut off the power.
Mechatrommer said : "switch should be the mosfets in the ESC"
Belrmar said : "i would try to check if the ESC's have some kind of power down pin that you can feed from the receiver."
I checked and the ESCs turn down power after 1 second of control loss and go to very low power 2 seconds after. If that's not sufficient, generating a low duty cycle PWM input for the ESCs just takes a single CMOS inverter IC and will cut the power entirely as long as the ESCs are responding to input (they do have firmware which can bug out, but their complexity is far lower than the flight controller so it's not likely).
Regardless of whether you use the ESCs or a MOSFET you will have to decide whether you want to latch the signal or not (ie. if you cut the engines, should it take power cycling to turn them back on). Also need to decide how to decode the PWM signal, you can do it with CMOS logic, resistors, capacitors and diodes. Or throw a small microcontroller at it.
The DAC isn't necessary. The MOSFET you chose is underpowered (6x40>100) and even at 100A it would need heatsinking.
PS. you can probably buy some modules which turn a servo signal into a binary signal too if you're lazy ... also don't you have a spare binary signal on the receiver by any chance?
