Author Topic: driving electro-mechanical 7 segment displays  (Read 1994 times)
Offline ice595Topic starter
« on: March 08, 2020, 05:46:06 pm »
Hi guys, I got a bunch of electro-mechanical 7 segment displays for Christmas and now I am trying make a clock out of them.
At first I thought I could just drive them like LEDs but it turns out they need a 12V 250mA pulse to flip each segment and to un-flip them I need to reverse the current pulse polarity.
So I would need something that can source AND sink current so the good'ol ULN2003A is out of the question.
High current op amps are too expensive, same with H-Bridge ICs.
SPDT SSRs are pretty much non-existent, but miniature mechanical relays like the RM699 series go for about $2 a pop on ebay.
Theres gotta be an easier/cheaper way of multiplexing them. any thoughts?
Online SiliconWizard
Re: driving electro-mechanical 7 segment displays
« Reply #1 on: March 08, 2020, 06:11:16 pm »
If you need to reverse the polarity, the common approach is to use a H-bridge. You can either find them all integrated, or implement them with discrete transistors. If the integrated option is too expensive, use cheap MOSFETs (you'll need 4 per segment - a lot to put on a circuit, but can still be pretty cheap.)
If it's acceptable to first toggle off all segments before changing the full digit, you may be able to find a trick to reduce the number of required transistors.
Offline FenTiger
« Reply #2 on: March 08, 2020, 06:23:51 pm »
Can you get away with only 2 transistors per segment if you use a split +12/-12 volt supply?
That is, tie one end to 0V and put a half bridge on the other end.
« Reply #3 on: March 08, 2020, 07:03:31 pm »
ok I just thought of another idea, and I think it can't possibly get any simpler.
I could drive 7x6 matrix with only 13 transistors and only 1 supply rail. (in theory at least)
since these displays only need a pulse (<100ms) to change state and doesn't require any power when idling
I just need to make sure those transistors aren't switched on for any longer than necessary, maybe a capacitor in series with the base so that even if my microcontroller crashes it won't set my house on fire.
Offline Prehistoricman
« Reply #4 on: March 08, 2020, 07:49:35 pm »
If you figure out how much current/voltage/time they take, that can inform some decisions on what circuit can and can't work.
I'd have thought that making an H-bridge of SOT-23 MOSFETs wouldn't be hard or expensive.
See https://www.digikey.co.uk/product-detail/en/nexperia-usa-inc/NX3008CBKS-115/1727-1278-1-ND/4386080
This is a convenient combined P and N-channel MOSFETs in one package. If you want to make a clock with 6 numbers, that would require 84 of these. It's cheaper to buy 100 and I think it's a pretty reasonable price.
Offline TomS_
« Reply #5 on: March 08, 2020, 08:07:14 pm »
This would probably produce a nice effect where you can see the display being progressively updated. Worth a try I think.
Offline ArthurDent
« Reply #6 on: March 08, 2020, 10:01:32 pm »
I have a 'pinclock' like the one shown below. It uses solenoids to either push the pins for the 7-segment displays out or to retract them to display the time. The idea is somewhat similar to the display you have.
Online Zero999
  • 0999
« Reply #7 on: March 08, 2020, 10:33:15 pm »
How about using high value resistors, with reasonably large capacitors in parallel? That would give enough kick to activate the solenoid, yet limit the continuous current to a safe level.
Offline floobydust
« Reply #8 on: March 08, 2020, 10:45:36 pm »
You can stagger the segment pulses in time, so pulsing only one segment then the next and so on- instead of hitting them all at once.  This lowers the peak current needed.
I would look at old flip-dot display driver circuits. We used to use capacitive-discharge and not need such a large power supply and no smoke if a driver shorted.
« Reply #9 on: March 08, 2020, 11:36:08 pm »
ok yeah, I will definitely experiment with the 13 transistor driver design.
Driving all 84 transistors in a discrete H-bridge design will be a nightmare in itself let alone the PCB layout.
« Reply #10 on: March 09, 2020, 01:28:38 pm »
There are these oddly cheap H-bridge drivers: https://www.digikey.co.uk/product-detail/en/akm-semiconductor-inc/AP1017AEN/AP1017AENCT-ND/5822594
No fancy features here (unlike the 10x more expensive ST parts). Unfortunately it would still be hard to route (good point) as there's 2 signals per driver to control.
