Putting 2 or more antennas signals thru one cable is normally done by diplex filters, which consist of two or more band-pass filters. Basically they only prevent that a signal which is off-range for one of the antennas doesnt go there. Comparable to the crossover networks in your stereo, directing bass to the subwoofer and higher frequencies to the high-band speakers.
You might find some interesting parts in the cable internet access products, I could imagine a wall plate with a TV port (47 MHz and up) and a Data upstream port (maybe up to just below 47 MHz, read specs, could be dependent on your region) might match your requirement of splitting between your vhf discone and a shortwave antenna.
If you dont consider designing your own diplexer, have a look at RF relais. You get them ready made as satellite tv accessories.
Using a preamp at some other place than right at the output of the antenna is quasi forbidden, e.g. behind a cable length or a relay. This will give quite a blow to the performance. If you really want to do it, run shortest possible cabling from the antenna to the relay and from the relay to the amplifier.
