Thanks Fchk. I’ve got some questions.
On X1, I assume that the load is connected before pin 6, which has the live line just before the shunt. Then, pin 1 is the return Neutral line (hence GNDA is the Neutral line).
X1’s pins 2 & 5 are a bit confusing. I would expect the live line connected at the C2 X2 class safety capacitor, with GNDA anyways being the Neutral return.
What does PL_OGD mean for the fuse? You’re using a 4A fuse, any particular specs on this, I.e fast blow?
Please correct me where my assumptions are incorrect!!
Thanks M
