Hello everyone!
This is my first post in the Forum!
I want to share you my power supply project progress. I have been using basic Lm317 power supply which i built four years ago, but i want capability to limit current when testing new circuits.
Specs:
- Two independent channels, 0-15V, 0-500mA
- Linear, TIP122 darlington series pass transistors
- Passive cooling, heatsink on back panel
- 40VA 2x15VAC toroidal transformer that I had already
- Zener references
- Lm324 OpAmp for sensing voltage and current, and driving CV/CC leds
- Low side current sensing, seven 10 ohm 0,6W resistors in parallel
- Analog panel meters for voltage and current readings, two per channel
- Switch to short output to set current limit
- Load switch
- Single turn wirewound potentiometers
I have already etched and assembled the circuit board, and it looks like working fine. Schematic is not ready yet, but I will share it when I have finished it. Transformers voltage is slightly low, but not too bad, no large ripple on 15V at 500mA with 3300uf smoothing capacitors. I intend to use toggle switch as load switch. I know it have that contact bouncing effect, but is it too bad practice if it does not overshoot? Next step is get sheet metal for case, and wait panel meters to arrive.
Thank you for advises and comments!
