Can two of those inexpensive boost converter boards you find on Amazon for a few dollars be used to create a +/- 12 VDC output, using a single 18650 cell? I know that this is possible for a single rail output, but I don't know if those boost boards can be connected for dual rail use. I haven't purchased any yet.
The obvious way to create a dual rail, battery powered supply would be to use two 12 V batteries, but that increases size, cost, and charging complexity.
Also, can anyone recommend a particular boost board that has low noise and ripple? The purpose is to power some op amps for use from 10 Hz to 1 MHz.
